Cracked frame
Old Jun 24, 2002 | 05:41 PM
Widgett's Avatar
Widgett
Default Cracked frame
Have any of you experienced cracks on the frame of your C3? I have a crack on the lower outside corner of the frame behind the rear lower control arm mount. It is right along the edge where the power steering piston connnects to the A shaped support bracket that mounts to the frame. I have heard of stress cracks in the welds on the crossmember, but this is not on a weld. This is the wall are right in the 90 degree bend. There is almost a quarter inch gap of material which has broken and is missing. The gap is not from and separation of the frame.
Old Jun 24, 2002 | 05:45 PM
BB wowbagger's Avatar
BB wowbagger
Default Re: Cracked frame (Widgett)
Just get a nice piece of 1/4 sheet metall and weld it...And then some paint..Then sell :smash: :smash: :jester
Seriously..Cant you just get a nice pice of metall and just weld it to the frame? :cheers:
Old Jun 24, 2002 | 06:41 PM
73-454's Avatar
73-454
Default Re: Cracked frame (BB wowbagger)
That is called Vette rot, your entire frame and winshield frame are rotten, take it directly to the bone yard, You have a very unsafe car.
Old Jun 24, 2002 | 06:49 PM
Wrencher's Avatar
Wrencher
Default Re: Cracked frame (73-454)
Ouch 73-454! Thats some brutal advice, but go ahead and determine if it is rot/rust and decide if you want to do the frame replacement if it is.
Hans
Old Jun 24, 2002 | 07:07 PM
lbell101's Avatar
lbell101
Default Re: Cracked frame (Wrencher)
Don't mind 73-454. He's off his medication - again.
Vettes frames are prone to rot in some locations. Alot of folks here have either fixed or replaced all or portions of thier frames. You need to do a complete inspection of your frame. Then search the archives for 'frame repair' or 'rusty frame'. Lots of different methods have been discussed and you will see what others have done.
Old Jun 24, 2002 | 08:25 PM
JB's Avatar
JB
St. Jude Contributor
Default Re: Cracked frame (lbell101)
Probably not rot at all. I've seen several vettes with cracks exactly where you describe--it's a weak point in the frame and they crack there all the time. It just needs to be welded and it will be as good as new--a cheap fix, shouldn't cost most than $100.
JB
Old Jun 24, 2002 | 09:33 PM
Paul L's Avatar
Paul L
A good welder can fix this (pic) and your problem.
Old Jun 24, 2002 | 09:43 PM
vetteflame79's Avatar
vetteflame79
St. Jude Donor '06
I had the same problem. took to a vette shop and he told me he has seen this alot in the 77-79 years--- don't know why... he took mine apart and welded it . been fine ever sence. :seeya
Old Jun 24, 2002 | 10:46 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
:smash: :smash: :smash: :lol:
Old Jun 24, 2002 | 11:07 PM
bigvette1's Avatar
bigvette1
Default Re: Cracked frame (427V8)
You guys can be brutal. "Don't mind 73-454. He's off his medication - again."
Don't drive it with a cracked frame - get it fixed is what he wants to say. A little brevity is good for the forum. Thanks for a good chuckle.
Old Jun 24, 2002 | 11:36 PM
LATNC3's Avatar
LATNC3
mine and Darcy bast have cracked frames......is this a GM manufacturing problem? i also have a chevy 1/2 ton with the same problem!!
Rod:cool:
Old Jun 25, 2002 | 12:04 PM
Widgett's Avatar
Widgett
Default Re: Cracked frame (LATNC3 (Rod R))
The frame doesn't show any signs of rot, the wall thickness is 1/8" or better. There is a stress crack and fractured metal missing. I'm the only owner of this car and it has never been out of north Alabama. It has never been exposed to salted road conditions, so I can't believe it's due to frame rot.
Old Jun 25, 2002 | 12:09 PM
MikeC's Avatar
MikeC
Its just from the stress of the hydraulic ram pushing and pulling on the frame for 21 years. Fix it... but make it bullet proof this time.
And ignore 73-454, he's just a troll.
To Cracked frame
