SLOPPY CONTROL VALVE???
Old Jun 24, 2002 | 07:03 PM
OkeeGuy's Avatar
OkeeGuy
Default SLOPPY CONTROL VALVE???
well...i replaced my steering ram today and i thought that was the end of my steering component replacement for a while...
much to my dismay...while sitting at the left front wheel while my g/f turned the wheel back and forth to bleed it i noticed a lot of play in the ball link on the control valve... :confused:
whats the deal with this? i once asked how id know if the valve needed replacement and was told that if it didnt leak, it was ok...
well...i guess technicaly they were right but what i think i need is this...
1- am i right?
2- if so...is it hard to replace?
3- will i need to re-bleed the system again?
Old Jun 25, 2002 | 07:49 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: SLOPPY CONTROL VALVE??? (SIGNGUY)
come on...dosnt anybody know??
hhhmmm???
Old Jun 25, 2002 | 08:53 AM
Tom454's Avatar
Tom454
The valve has an internal adjustment for the ball & socket.
You have to disassemble the valve to make the adjustment, and there is a steel shim gasket between the halves of the valve that usually must be replaced when you disassemble the valve. The gasket & seals come in a rebuild kit.
GM used to sell a valve ball/socket/seal/gasket kit for cases where the ball stud etc was worn out. Don't know if it's still available.
I would try the gasket/seal kit first (along with an adjustment), and if it doesn't help, then get a NEW valve. The rebuilt units don't seem to be very reliable..... poor workmanship.
When you remove the old valve, be sure not to mess up the male threads on the rod, or the female threads in the valve.... Bubba usually accomplishes this by sticking a screwdriver in the slot (where the nut/bolt tightens) to unscrew the valve from the rod. Use a pipe wrench instead.
You will have to "re-bleed" the system after the repair... but IMOP bleeding a PS syetm is simple.
The adjustment I am referring to is NOT the adjustment that is for centering the valve, which is the small nut under the grease cap at the end of the valve.
Old Jun 25, 2002 | 09:12 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: SLOPPY CONTROL VALVE??? (Tom454)
I had a hard time getting my metal seal holding tightly around the valve ball joint. I see the kit you have pictured above has the screw down seal. Where is it from?
[Modified by Eddie 96, 8:13 AM 6/25/2002]
Old Jun 25, 2002 | 06:54 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: SLOPPY CONTROL VALVE??? (Eddie 96)
thank you both for your help...
the kit is from ZIP and its $37 and change...
is it the kit for me?
i hate to replace the whole valve when it is otherwise working fine and not leaking...
Old Jun 26, 2002 | 08:27 AM
Tom454's Avatar
Tom454
I've seen the kits recently for about $29. but the content does vary.
To SLOPPY CONTROL VALVE???
