just installed hearders+sidepipes on my 69 bb vette, no room for# 3 spark plug, to get in runner #acr 43xl piugs,do I go to a smaller plug or what?someone HELP!!!!!!
put a small piece of vacuum hose(straight and an inch or so long) thread it in till your sure it's going in properly then put your socket on and tighten with an open ended wrench.
and one more thing the borgeson power streeing box is in the way!!!
Great roads for the Vette but ya don't want to get the rear end hung out to far on these 2 lane roads when ya don't know if a Coal truck loaded is coming the other way.
LORDY
Regular AC delco and the like will not fit. However I found that NGK's are short enough with headers for my side pipes. On the iron heads I used UR45's. The accel's mentioned will fit too.
NGK BKR6E plugs on Hookers with 2-1/8" primaries work fine.
I am installing a msd complete kit, it said to gap the plugs to start at 50 to 60 gap. what plugs can I use at 5/8 for a small plug with the heards , power streeing box in the way?
This picture is of an NGK BKR6E short plug on the number 3 cylinder of a 468 with Hooker 2-1/8" primaries. See my post above. The number 6 is the plug heat range. A 5 is hotter, 7 is colder.
This is a photo on the same engine with a regular deep 5/8" socket and a 1" extension. Plenty of room.
I normally use a spark plug socket, but the metal clip from the plug wire broke off on this plug and the rubber insert in the spark plug socket wouldn't fit over the clip.
