I just purchased a 78 pace car with only 24K miles. It is an automatic with with the L82 engine. Does anyone have any suggestions on making more horsepower (i.e., HEI ignition coil, K&N filter, exhausts, etc). I prefer not spending a fortune. Thanks!! :smash: :smash: :smash: :smash:
Headers, dual exhaust, and a good intake manifold would bump it up to high-200 hp range.
The ZZ4 with 1 3/4" headers and low restriction exhaust makes 355 hp. You could do headers and exhaust on your car now for a quick pick me up, and install the ZZ4 later when money's more convenient.
-Steve
-Steve
I thought that I read, somewhere on the Forum, that the HP ratings on GM crate engines were gross, not net as they did not know what accessories would be run on the engine. If that is the case, I believe the GM ads state 355 HP on the ZZ4, how can you have the same HP with an exhaust system installed? Any corrections to my thinking are welcome.
Re: pace car needs more power (Chris@VetteFinders)
You'll need more than exhaust and an intake to get to the "high 200" range.
A new cam is really the best bet in addition to those parts you mentioned.
Ditto. I have hedders, hiflow cat and Flowmasters and my engine is making 220hp/250tq according to my dyno sheet. The shop installed an advance kit in my distributor and re-jetted my Quadrabog. The L82 doesn't come into its power band until 2500+. The top end of this motor(intake manifold&heads) is strangling the cam, along with the exhaust system. Good luck to you and hey, how come you didn't buy my pace car, huh? :jester
The L-82 cam is by no means tame, Rhys. .45/.46 lift? That's about a step below your XE268.
I think the L-82 is good for 260-280 hp with headers, a performer intake, and exhaust. SD Pace Car claims 220 hp, if that's rear wheel, then that would come out about 260 net engine hp, the bottom end of my guess.
The LM-1 makes 265 engine hp through 1 5/8" headers, 2 1/4" true duals and mufflers, w/ 1.94 x 1.50 heads, and performer intake. I'm almost certain the L-82 could make more than 265.
LM-1 cam: .39/.41 (Same as L-48)
L-82 cam: .45/.46 . Hmmmm. Is there a difference here?
Well, yes, the LM-1 has different heads than the L-48/L-82, and I don't know which heads flow better, but the L-82 *is* fitted w/ 2.02/160 valves. *shrug*
Hence, this is why I believe the L-82 could make high 200's as far as ENGINE horsepower goes. Flywheel.
Glen242- The ZZ4 was rated with 1 3/4" headers feeding into 2 1/4" pipes with "low restriction" mufflers. I believe I stated that in my post.
-Steve
I disagree. Lets see someone prove me wrong (with actual results) 220 is not rear wheel, btw
-Steve
[Modified by Pacin'California, 6:47 PM 6/25/2002]
[Modified by Chris@VetteFinders, 1:32 PM 6/26/2002]
[Modified by Chris@VetteFinders, 11:16 AM 6/27/2002]
I'll stand by my post.
I believe with a good intake manifold, 1 5/8" headers, true dual exhaust and good mufflers, the L-82 would be capable of 250+ HP.
Headers and exhaust are a good install on the motor, as you can recycle them if you decide to go w/ a crate motor or make any other changes to your motor in the future.
-Steve
I just now called the Dyno Shop (3:40PM WCT) in Santee, CA. I specifically asked about the print out sheet displaying HP/TQ. I quote, "It is to the ground as far as the numbers generated." I am with Pacin on this one.
-Steve
Ummm...nobody has mentioned removing the smog controls (for test purposes only, of course -- wouldn't want to break no laws or nothin like that)...
Rumor has it that the AIR Pump sucks 10 hp at the engine. Of course, no one has ever taken it off to prove that point, cuz everyone on this forum believes that smog equipment is necessary! :smash:
Disconnecting the belt could free the engine up. Removing the pump entirely would clean the compartment up and save weight.
The 78 L-82 has 3.55 gears from the factory w/ the automatic transmission(3.70 w/ manual). I wouldn't change unless you're dying to spend a few hundred dollars or the rear gearset is in its dying days.
Also, get Lars's timing kit. Timing is a significant factor in engine performance.
I lowered my 0-60 time by almost a second tweaking with the timing. (Using G-tech!)
-Steve
