C3 Fuel leak (sending unit)
Old Jun 15, 2013 | 06:09 PM
ONeill202's Avatar
ONeill202
Default C3 Fuel leak (sending unit)
My car has been smelling funny (like fuel) for the past few months. I never suspected the fuel tank because it was replaced with a new tank back in 98. Today I decided to inspect the spare tire and things got real interesting. I looked up to where the sending unit is located and noticed a dark greasy substance that smelled a lot like fuel. The spare tire was covered with fuel as well. It appears to be coming from the very edge of where the sending unit is located. This is new to me so any advise will be greatly appreciated. I'm not sure if I need another fuel tank or just the sending unit gasket. Thank you!
Old Jun 15, 2013 | 06:31 PM
jnb5101's Avatar
jnb5101
there's no way to know what you need until you remove the sending unit. drain what gas you can into suitable containers by cutting the rubber hose (you'll want a new one, anyway). place a large plastic tub under the sending unit and remove it(about a quart of rusty gas-water mixture will spill out). then report back here.
Old Jun 15, 2013 | 06:33 PM
ONeill202's Avatar
ONeill202
Will do thank you.
Old Jun 15, 2013 | 06:58 PM
loup68's Avatar
loup68
Army
I am pretty sure that your problem will be the "O" ring seal. However I also have had the solder joint break loose on the fuel line tube. Lou.
Old Jun 15, 2013 | 08:21 PM
ONeill202's Avatar
ONeill202
You might be right. The red area which I suspect is the "O" ring seal feels real gummy. Does anyone know if a special tool is required to remove the sending unit?
Old Jun 15, 2013 | 08:53 PM
TimAT's Avatar
TimAT
Technically, yes a special tool is required. BUT- a small brass hammer and a medium size punch works very well.
Looking at your picture, the lock is positioned so the locking lugs need to be rotated counterclockwise. One of the tabs you can tap on is just above and to the right of the sending unit wire. (there are 3 of them). As you tap on it, try and keep the inner ring as centered as you can- makes it much easier to turn.
Disconnect your sending unit (twist and gently pull), and drain the tank as above.
Old Jun 23, 2013 | 05:38 PM
ONeill202's Avatar
ONeill202
OK, here's what I discovered:
The main pipe that feeds the fuel had a weakened solder joint (see picture). In an effort to save a few bucks, I cleaned the area with sand paper and re-soldered it using silver solder. I reinstalled the unit and I am leak free. A new strainer and gasket was installed as well. I'm not sure if my repair will last or even if soldering it with silver solder is appropriate, but it's working. Please comment if you think my repair won't last and if a better solution might be to just order a new sending unit. Thanks!
Old Jun 23, 2013 | 06:29 PM
80-81vetteguy's Avatar
80-81vetteguy
someone told me u have to drop the tank out to replace the sending unit on an 81 is that true?
Old Jun 23, 2013 | 06:34 PM
loup68's Avatar
loup68
Army
Oneill 202, You did a good good job and it hopefully will be fine. I am sure that the original solder used was 50/50, but you can't get it that easy anymore. Lou.
Old Jun 23, 2013 | 07:38 PM
ONeill202's Avatar
ONeill202
I'm not sure about an 81 maybe someone can jump in and comment. Mine is a 70 and I didn't have to remove the tank to replace it. However, I'm still scratching my head wondering why they placed the sending unit on the bottom of the tank where it can easily leak and maybe blow up.
Old Jun 23, 2013 | 07:46 PM
ONeill202's Avatar
ONeill202
Thank you. Here's another picture installed with the repaired sending unit. I got about 10 gallons in it now and I've been looking for a leak for the past two days -- nothing yet ... keeping my fingers crossed.
Old Jun 24, 2013 | 11:01 AM
AirborneSilva's Avatar
AirborneSilva
On my 76 I have to. Well you don't have to drop the tank completely but you do have to take everything else apart as if you were going to take it out then just rotate is 90* towards you then you can pull out the send unit, just had to do that on mine last week.
Old Jun 24, 2013 | 03:14 PM
80-81vetteguy
estimated time it took?
Old Jun 24, 2013 | 05:18 PM
ONeill202's Avatar
ONeill202
I suspect this is what you are up against?
Old Jun 24, 2013 | 05:25 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
I removed the tank to clean and restore, as well as install a new screen on the pickup. My aggressive cleaning apparently weakened the tube's solder joint, because it started leaking after putting everything together and filling with fuel.
After draining the tank again, I decided discretion was the better part of valor and opted to install a new sending unit. For around $120, it was worth it...considering the danger of fuel leaks and the pain in the a** it is to deal with. Hopefully your repair holds...but I was advised by an HVAC expert who regularly solders tubing...including aluminum...not to mess with it.
Old Jun 24, 2013 | 05:38 PM
ONeill202's Avatar
ONeill202
Interesting -- Thank you! I'll definitely keep an eye on it and if it doesn't hold it's headed to the trash can.
Old Jun 24, 2013 | 08:51 PM
AirborneSilva
Took about 3 hours from start to finish and I don't get in a hurry on things so if your fast you can do it in just over 2 hours I would guess.
To C3 Fuel leak (sending unit)
