rough running
It seems i had more then one problem. I found the following issues while trying to fix the rough running.
- Bad power valve in Holley carb
- Vacuum leak (big hole) in vacuum hose
*** Then throttle ok but occasional rough running still a problem....
- Sticky intake valve..... (this was an older - late 60s - junk yard engine)
i added Marvel Mistery Oil to my crankcase oil and gas tank then, after driving for a few hundred kms, the engine is running MUCH smoother.
My car is fun to drive again
Got sick of adding it then tried, Gumout Regane.
That was the secret. Now after two treatments, my engine runs amazing.
