Tach capacitor rating?
Old Jun 19, 2013 | 10:41 PM
FriscoScooterTrash's Avatar
FriscoScooterTrash
5th Gear
Default Tach capacitor rating?
Only one I can find is from Davies Corvette Parts for $40. Looking for the farad, voltage and temp ranting.
Mine is leaking to ground and prevents the ignition from discharging the coil, btw.
Old Jun 19, 2013 | 11:23 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
It is actually a filter... it knocks the edges off the square signal before it hits the tach....
I have them at 37.00 but if you use the forum sale code you'll get 10 percent off that too..
http://willcoxcorvette.com/product_i...ducts_id=26320
Old Jun 20, 2013 | 08:27 AM
7T1vette's Avatar
7T1vette
If you are referring to the 'radio noise suppressor' capacitor (connected between coil terminal and ground), you probably don't need it [unless you still have the original Delco radio].
If you are referring to the 'tach filter' that is in a canister mounted on the intake manifold (connected to the distributor), that filter houses a network of capacitors and resistors inside the case. You can disassemble it to find the component ratings....or purchase a new one for $40.
To Tach capacitor rating?
