Yet another headlight problem
Old Jun 20, 2013 | 11:42 PM
Jim78SA's Avatar
Jim78SA
Default Yet another headlight problem
First and foremost, yes I did a search. The problem is my headlights will not go up, or turn on. While looking around under the hood, I found a vacuum line with a black locking cap hanging down from the driver's side mid frame, below some sort of light relay. Also, I see the previously mentioned relay that does not have a wire hooked up where it says lights. Problem is, I do not see a wire. Any ideas? Thank you in advance. If you all don't immediately know what i am talking about, I will take pictures tomorrow.
Old Jun 21, 2013 | 12:36 AM
Jim78SA's Avatar
Jim78SA
Also, while looking around under the dash, I found a red wire and white wire with a grey connector not connected to anything? is this my wire for my lights?
Old Jun 21, 2013 | 02:42 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Raising and lowering the headlight doors is 100% vacuum. Lights on or off is 100% electrical. You have two different problems. Will the headlights raise using the override under the steering column?
Post a pic of what you're calling a vacuum line with a black cap.
The gray and white wires you found are not likely to be headlights. Headlight switches plug up off the main dash wiring harness.
What model year do you have?
Old Jun 22, 2013 | 02:06 PM
Jim78SA's Avatar
Jim78SA
I have a 78 anniversary. That is what I figured. No the lights will not raise with the override either. I did a vacuum test at different places all along the system and I am only getting 7 lbs. The windshield wipers work like a champ though. The car is heavily cammed though. I heard that may lower the vacuum pressure? I have no idea what cam either. How do i raise the vacuum pressure.
Old Jun 22, 2013 | 02:08 PM
Jim78SA's Avatar
Jim78SA
Also, i confirmed the wires are not part of the light system.
Old Jun 22, 2013 | 06:11 PM
Jim78SA's Avatar
Jim78SA
May be a stupid question more or less just to confirm that is does effect the vacuum, but when I press the brake pedal down, I hear a hiss. I am sure it is the booster. Breaks feel fine though. Can this affect my vacuum? I have had this car for two days, and so far the only issues are the headlights, bot vacuum and electrical, please someone help!
Old Jun 22, 2013 | 06:43 PM
Peterbuilt's Avatar
Peterbuilt
Default How To:
For the headlights not turning on:
The red wire brings power to the switch, you can check there and you can check the ground on the radiator support.
78 schematic:
http://www.vetteprojects.com/bmv/mis...tte%201978.pdf
For the headlights not going up and down:
http://www.corvette-101.com/vacuum.htm#top
The leaky booster is next.
Old Jun 22, 2013 | 07:00 PM
Jim78SA's Avatar
Jim78SA
Pete thank you! I saw the Corvette 101 during my search. I suspect that the way one of the the PO routed the vacuum assembly may be the culprit. I will take and post a pic. He has the lights, brakes, and wipers all t jointed off the intake. This car is gorgeous inside and out. If I can get these things fixed it would be perfect. He even disabled the dome and under dash lights. Don't get why he did that. And the guy who I bought it from put a Holley 750 on a mild rebuild. Thing runs real rich, like head ache rich, and the leaking booster isn't helping since the idle is steady when you depress the pedal.
Old Jun 22, 2013 | 07:11 PM
Peterbuilt's Avatar
Peterbuilt
For the vacuum start at the manifold and cap off everything except the headlight system and follow the diagram step by step.
Between the age of our cars and the Bubba's that came before you never know what you may find.
Old Jun 23, 2013 | 02:10 PM
Jim78SA's Avatar
Jim78SA
Last night, I was tinkering around and I hear a hissing from the three way check valve, is that normal?
To Yet another headlight problem
