Timing Question(s) - Riddle Me This
Old Jun 25, 2013 | 08:36 AM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Default Timing Question(s) - Riddle Me This
I tried to PM Lars, but his box is full...
I'm running a Tach Drive HEI Distributor in my '73, in Lar's timing info page, he specifies removal of one of the springs in a Points Distributor to set timing, is this necessary with an HEI distributor as well? (36degrees Total Etc.)
Secondly, what Recurve kit's do you folks recommend.
As Always, Thanks
Scott
Old Jun 25, 2013 | 08:49 AM
sstopczy's Avatar
sstopczy
E-mail him: V8fastcars@msn.com
Old Jun 25, 2013 | 09:34 AM
oldalaskaman's Avatar
oldalaskaman
he rarely answers pm's, always answers e-mails
Old Jun 25, 2013 | 10:05 AM
Chinaski's Avatar
Chinaski
St. Jude Donor '14
Originally Posted by MelWff
Yes it is necessary. The whole point is that you can set the total timing at a lower RPM with one as opposed to two. The Mr. Gasket for HEI is the one recommended by Lars, it's not mentioned in the paper you have?
I saw the MR. Gasket stuff, but it didn't mention removing a weight on a HEI distributor, just points.
Old Jun 25, 2013 | 12:00 PM
lars's Avatar
lars
Actually, my paper specifically states to not remove a spring on HEI - removing a spring on HEI will change the length of the curve and produce a faulty total timing indication. The paper only recommends removing a spring on the points-type distributors, if you have the stock, heavy, factory springs installed. Removing a spring on the points-type distributor will not change the length of the timing curve, and it will allow you to set the total timing at a lower, safer rpm.
Lars
To Timing Question(s) - Riddle Me This
