shaking, in my seat
Old Jun 25, 2013 | 05:24 PM
vettster666's Avatar
vettster666
5th Gear
Default shaking, in my seat
Hello all have an 1981 vette, I got this shake in the rear drive train,
when on the gas you feel it, get off the gas shake smooth out, you feel it right in the seat.
I balanced all four wheels,
Changed u-joints on drive shaft,
Checked out shorty's u-joints, all tight,
Rear wheel seals are good,
motor mts. good,
differential ? don't know.
Anyone else come across anything like this?
Thank You for any help.
Phillip vettster666
Old Jun 25, 2013 | 05:29 PM
Schaggy's Avatar
Schaggy
I'm no expert, but how are your trailing arm bushings?
Old Jun 25, 2013 | 05:48 PM
vettster666
5th Gear
Thx for answer, all bushing are great shape
Old Jun 25, 2013 | 09:24 PM
buckhorn 76's Avatar
buckhorn 76
sometimes if the driveshaft or half shafts are re-installed 180 degrees out they will be unbalanced and the car will shake like hell.
Old Jun 25, 2013 | 09:44 PM
SIXFOOTER's Avatar
SIXFOOTER
Check for runout on the rear wheels, might have a bent hub.
Old Jun 26, 2013 | 06:36 AM
7T1vette's Avatar
7T1vette
When at speed, and the car is shaking, put the trans in 'neutral' and coast at that speed and check whether vibration is about the same or much reduced. If the same, your problem is in the drivetrain after the trans. If the vibration is much better, the problem is in the engine/engine-accessories/transmission environment.
Old Jun 27, 2013 | 08:53 AM
vettster666
5th Gear
Thank you all for helping, I'll check each one out.
Old Jun 27, 2013 | 09:09 PM
63split63's Avatar
63split63
Change the rest of the u-joints . The only way to really check a u-joint is to take it apart . While you have it apart you may as well put new ones in .
Bill
To shaking, in my seat
