Changing Headlight Bulbs On A '69
Put the lights in the up position and unscrew 4 bolts holding the fiberglass light cover. 2 on either side and 2 that screw into the front top of the cover. The top ones are small and don't lose them!
Take cover off by wiggling it forward.
Each bulb has 3 Philips head machine screws that hold the headlight bulb retainer ring. They are small and a little rust. Take them out ,pull the bulb, unplug the back and reverse to install.
Do not kill the screws!!! Just snug
The screws are small and into aluminum so they can be "fused" easily.
Also the screws in the headlamp rings are very small and frequently rusted in, this combined with being phillips makes for easily stripped.
Give all screws a good shot of PB blaster (liquid wrench, etc) and let it work.
Also, putting a location in your profile may lead to someone /some club in your area that might like to help out here and there.
Forgot to mention, there are two screws on each lamp that adjust the aim of the headlamp, don't touch those two
you can see them (sort of) on here
At the top (bottom of the picture) and on the side outsides of each lamp
The smaller screws holding the lamp ring are noticeable different. One is shown on the bottom (top of the picture)
Just beside the spring near the middle of the picture
Mooser
