L82, Forged piston "slap"
Old Aug 14, 2013 | 11:58 PM
Vet76te's Avatar
Vet76te
Ok,...so I have come to the realization that the noise is normal and nothing to be of concern. However, I hate it!
How can I remedy this problem?
Do i Just replace the forged pistons with a cast piston? If so, will I lose any of the current power? Will replacing the pistons cause a balance problem? Can I get by with replacing the pistons without a rebore?
Again, it has good power, great compression, no blow by, does not burn ANY oil, great oil pressure,....just noisy .
I don't want to do a complete overhaul if I don't have too,.... But I'dike to quieten it down.
Old Aug 15, 2013 | 12:04 AM
mds3013's Avatar
mds3013
My advice is to worry about something else. Just being a smart azz. Can't help it sometimes. Run it. mike...
Old Aug 15, 2013 | 07:07 AM
bashcraft's Avatar
bashcraft
Exactly.
Or you could turn the radio up louder.
Old Aug 15, 2013 | 07:55 AM
Vet76te's Avatar
Vet76te
I know I shouldn't worry about it,..but it's SO loud when cold its embarrasing. For example,...I was at a car show cruise in last Saturday. Everyone was admiring my Vette. She stole the show. However, after a couple of hours, I decided to leave and fire it up,...everyone looks in my dirceteion and I had two people come up and ask, "Whats wrong with it"?
She looks like a beautiful sports cars but sounds like a diesel truck.
Old Aug 15, 2013 | 08:20 AM
bashcraft's Avatar
bashcraft
If it's that loud, it's quite possible that the problem is something other than piston slap.
Old Aug 15, 2013 | 08:56 AM
REELAV8R's Avatar
REELAV8R
Change the oil to something lighter. See what happens. I suspect you are hearing more than piston slap.
The Mobil1 0w40 would make a big difference and it has the required 1000 ppm of zddp that most recommend for flat tappet engines. It is also synthetic, all better for your engine.
If your not ready to make the leap to 0W then try some 5W something oil. Just know that most recommend 1000 ppm minimum of zddp for a flat tappet engine.
If you don't know what zddp (zinc) is do a search here You'll get TONS of opinions on the subject.
Read this it may help with your decision.
http://ferrarichat.com/forum/faq.php...tor_oil_basics
Old Aug 15, 2013 | 10:52 AM
AboveTheLogic's Avatar
AboveTheLogic
Can you get us a video or sound clip of the noise?
Old Aug 15, 2013 | 02:15 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Tell them it is a special sound that only your Vette makes.......
As mentioned above, just drive and enjoy it, the sound goes away after the engine warms up...again my 75 L82 gave me many trouble free miles with that slap.....have fun........Tom
Old Aug 15, 2013 | 05:18 PM
hugie82's Avatar
hugie82
You can try pulling plug wires one at a time to see if its one piston or multiple.
try a different oil?
maybe a hotter thermostat 200-210*
If it really is a piston slap there really isn't much you can do....
My LQ9 in an SS Silverado had a noticeable slap and it went away after about 60,000 miles. I figure carbon build up quieted it down.
Run it until it blows!!! then makes sure your tolerances are tight, next time around.
Old Aug 15, 2013 | 05:59 PM
cv67's Avatar
cv67
St. Jude Donor '05
If its any consolation my 383 has slap it can sound mild or sometimes bad depending when cold. It can really make you sometimes
By the time shes warm its fine, all about play and listening to the solid valvetrain. Just the way they are
Build em loose quick 50 mi break in and give her hell.
Old Aug 15, 2013 | 10:53 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Oil additives or rebuild - anything in between is not worth the effort.
Heck try some ol'e STP, Lucas oil treatment, RESTORE or the like. U should google this also. Why not just try a new additive at each oil change? What have u to lose?
To replace pistons means a full bore and hone also let alone polish the crank and new brgs - with heads off vlv job to. Now more like $1500.
Good luck with what u choose and if u find something that works please share and post here,
cardo0
Old Aug 15, 2013 | 11:12 PM
LS4 PILOT's Avatar
LS4 PILOT
try using a high zinc oil and hi test pure gas for a while to see if that helps,
my L82 in the 74 z28 makes no noises like you describe , that's weird , the engine does run a lot better on th premium pure gas . I use Amsoil high zinc content.
good luck
Old Aug 15, 2013 | 11:25 PM
  #33
lars's Avatar
lars
If your "piston slap" is so loud that it's embarrassing on startup, it's probably not piston slap. I run a lot of forged piston engines, and I never have piston slap any louder than the solid lifter cams I run, when the engine is cold. When the engine warms up, real piston slap should go away. Completely. When warm, a forged piston engine should run as quiet as a cast piston engine.
The last time I had a "piston slap" that was loud and did not go away after warm-up, it was actually a floating piston pin that was failing. I'd suggest you pull spark plug wires off one at a time and find which cylinder is the offending cylinder. Then, troubleshoot the real problem. An engine should not knock like that after warm-up unless you have a significant problem.
Lars
Old Aug 19, 2013 | 09:55 AM
  #34
bashcraft's Avatar
bashcraft
Then it wasn't from a piston. Piston slap won't go away.
Old Jul 14, 2014 | 05:43 PM
  #35
hugie82's Avatar
hugie82
Carbon build up on the skirts I would guess but it went away. I know what a piston slap is and the dealer said the the same thing. Still running like a raped ape at 130,000 miles.
