75 head lights
Old Jul 3, 2013 | 10:51 AM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default 75 head lights
Ok when I got car lights would not come up, so I have checked the vacuum, replaced some tubing, found vacuum relays not working. So I replaced vacuum relays, installed check valve. So now they come up and go down, a accomplishment but a little slow, passenger side even slower going up and down. Any ideas
Old Jul 3, 2013 | 10:55 AM
Peterbuilt's Avatar
Peterbuilt
There is a seal (grommet in the link)) in the actuators that goes bad.
You can buy just the seal kit if needed.
http://www.corvette-101.com/vacuum.htm#actuator
Old Jul 3, 2013 | 11:05 AM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default Headlights
Thanks I will check
Old Jul 3, 2013 | 02:06 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Rogerl
...now they come up and go down...a little slow...Any ideas...
Quit while you're ahead.
Old Jul 3, 2013 | 08:11 PM
Rogerl's Avatar
Rogerl
St. Jude Donor '14
Default Lights
You might be right.
To 75 head lights
