No key start, but remote starter works
Old Jul 4, 2013 | 03:38 PM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Default No key start, but remote starter works
My 77 will not start from the key switch. All the electrical stuff works otherwise. Bubba put a remote start button under the dash and i really want to get it back to starting from the ignition switch. Where to start?
Old Jul 4, 2013 | 05:04 PM
speedreed8's Avatar
speedreed8
he probably bypassed the switch underneath the dash on the column or the neutral safety switch on the shifter.(automatic).
Old Jul 4, 2013 | 07:07 PM
my 76 ray's Avatar
my 76 ray
I'm with Speedreed. I would get a test light or multimeter on the neutral safety switch and turn the key to see if you have power to the switch.
Old Jul 4, 2013 | 10:47 PM
CaseyJones's Avatar
CaseyJones
Thanks! I'm taking the console out now so I will check that.
Old Jul 4, 2013 | 11:51 PM
'75's Avatar
'75
My wifes 77 had an aftermarket security system, probably installed shortly after new, that would use a key inside near the hood release handle. It would lock the hood latch from opening and also interrupt the start circuit. The installer had tapped into the purple wire in the engine compartment that goes to the starter solenoid. I took it all out and repaired the poor wiring job.
Old Jul 5, 2013 | 12:44 PM
my 76 ray's Avatar
my 76 ray
On that neutral safety switch there will be a purple wire and a purple with a white stripe. I believe it is the purple/white that comes from the ignition switch. If you have power there when you turn the key to "start" then your ignition switch is good. Then you can jumper the purple and purple/white wires and try to start using the key again. If it starts then the neutral safety switch is bad.
Old Jul 5, 2013 | 01:44 PM
CaseyJones's Avatar
CaseyJones
Good advice from all. I appreciate it!
To No key start, but remote starter works
