heat riser
Old Jul 7, 2013 | 03:37 PM
namvet6869's Avatar
namvet6869
Default heat riser
do I really need the heat riser on my 81? riser is good but vacuum part is bad. don't think I can just buy the vacuum part.
Old Jul 7, 2013 | 06:19 PM
7T1vette's Avatar
7T1vette
Only if you are planning to drive it in below-freezing weather. Otherwise, just disconnect it. But, make certain that the valve always remains in the "open" position (or remove the valve completely).
Old Jul 8, 2013 | 09:14 PM
gcusmano74's Avatar
gcusmano74
IMHO, only lose the heat riser if you have an aluminum intake manifold. An iron one will take too long to warm up.
IMHO.
To heat riser
