74 L82 overheating issues, need help
Old Jul 7, 2013 | 07:56 PM
Lonestarman90's Avatar
Lonestarman90
1st Gear
Default 74 L82 overheating issues, need help
I'm new to this forum, but I was hoping for some useful help. My friend and I have been working on a customers 74 Vette for some time and have been having issues with the engine staying cool. We have put in a new triple core radiator rated to 900hp, replaced all hoses, used water wetter with water for the cooling system and have the timing at 9 degrees, we put new plugs gapped at 45thousandths with new braided plug wires, plus a Mallory cap and rotor. Plus we have installed a pusher fan in front of the condenser to further cool the system. With the old radiator the car would idle over 200, and when we drove it I'm under 10 mins it would be almost to 260. We replaced the thermostat and radiator, now it stays very cool at idle when first started up, taking almost 15 mins to get up to temperature, but once we drive it the motor heats up gradually until it hits 260 after maybe 15 Mins of city driving. Our first thought was an air pocket but we bled the system with an open funnel for maybe 20 mins and turned the heater on. Unfortunately the engine is still getting hot. We checked plug wires to make sure they were On the correct plug and cylinder. I apologize for the long post but we are somewhat lost as to why it's still overheating. We saw on some posts online that at idle the timing should be at 18 degrees, but we are currently at 9. Could this be our problem and what is the recommended timing on the L82? Any input would be greatly appreciated!!
Old Jul 7, 2013 | 08:16 PM
cv67's Avatar
cv67
St. Jude Donor '05
Was it over heating with the old radiator at all?
Fan clutch good, shroud sealed, air dam in place etc?
Hate to say stuck 'stat guessing youd know if it was
Old Jul 7, 2013 | 08:21 PM
'75's Avatar
'75
First make sure the fan clutch is working properly, with a hot engine, shut it off, the fan should stop quickly also. Make sure the foam seals are in place to stop air from going around the radiator and sealed so the fan has to pull air through the radiator and not gaps between the shroud and core. The other important item is the plastic spoiler under the front of the car. It interrupts air flow under the car and forces it up into the lower valance openings in front of the radiator.
Old Jul 8, 2013 | 09:06 AM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Besides the suggestions mentioned above, IMO, could it be that the water pump is defective??? It almost seems like there is some obstruction blocking the flow of your coolant. The only other item as mentioned before would be the thermostat, which you replaced already. What temp stat did you install? Even when your moving in city driving the temp should be coming down, and it seems to take quite long for it to warm up. The only other thing I can think of is, even though it is a brand new radiator, could be also be defective in that the coolant is not flowing through properly.
It just seems odd about such a high temp in a C3, the ones that I have had in the past, never ran above 210 degrees in stop and go driving, (with the AC on) and when they did, I thought that was high.
Another thought, do a pressure test on the system, when I took delivery of my 75 L82, after a few thousands miles it was really running hot, and loosing coolant, couldn't figure out the problem, did the pressure test and turned out to be a pin hole size split in a radiator seam and that from the factory, brand new!!!
Old Jul 8, 2013 | 10:32 AM
jb78L-82's Avatar
jb78L-82
All good suggestions. Sounds like an obstruction somewhere as well. 3 core radiator rated to 900HP? Corvettes came with a 4 core brass radiator. Water pump, maybe? I have a 78 L-82 with a Dewitts Aluminum radiator with a Stewart Stage 2 aluminum water pump (180 Thermostat) and yesterday in 95 degree high humidity heat the car never went over 175-180-either idling or at speed on the highway.
Old Jul 8, 2013 | 10:38 AM
CaseyJones's Avatar
CaseyJones
St. Jude Donor '15-'16
Cracked head or leaking head gasket? I'd check the pump first. Impeller may be bad. Are you sure the sending unit is good?
Old Jul 8, 2013 | 12:08 PM
Mike Ward's Avatar
Mike Ward
First thing you need to do is get an IR gun and measure actual temps, particularly at the thermostat housing. I have my doubts that your 260 readings are accurate.
Old Jul 8, 2013 | 02:03 PM
DaveL82's Avatar
DaveL82
Cehck to make sure rad seals to core support with foam seals. Must have no leaks. Make sure fan shroud is fully sealed to rad with foam seals. Make sure core support is sealed to hood with foam seals. This fixed the problem on my 80 L82 with stock rad.
I now run a dewitts aluminum rad and their own spal fan kit and shroud to save weight and did away with pump mounted fan
C3 vettes must have no leaks around radiator or fan will pull a lot of air past not through rad and it only takes small leaks.
Check items others mentioned and timing.
Old Jul 8, 2013 | 02:45 PM
my 76 ray's Avatar
my 76 ray
The only thing I haven't seen covered here is the radiator cap. Make sure it is holding pressure in the system.
Old Jul 8, 2013 | 02:49 PM
qwank's Avatar
qwank
missing air dam or crack head/head gasket
Old Jul 8, 2013 | 03:03 PM
illenema's Avatar
illenema
Please keep us updated on you findings
Old Mar 20, 2020 | 08:11 PM
Lachymac1's Avatar
Lachymac1
Disregard.
Bottom of thread reply woes.
Old Mar 20, 2020 | 08:21 PM
Dcott's Avatar
Dcott
Cruising
This build has maybe 200 miles on it. I built the engine myself. I’m not losing coolant that I can tell at least everything coolant wise is sealed I’m not smelling it in the exhaust or seeing any signs of it in the oil. Also had the heads pressure tested when they were getting resurfaced and getting shaved down to take up to a 600lift
I don’t see where it says anything on the radiator description about hp rating. Just 3 row all aluminum
Old Mar 20, 2020 | 09:00 PM
lars's Avatar
lars
Dcott -
You're posting in a 7-year-old dead thread. Start a new topic...
Old Mar 20, 2020 | 09:04 PM
HeadsU.P.'s Avatar
HeadsU.P.
This is happening every week. Somebody revives the dead.
I would like to see any post more than 3yrs old automatically deleted.
Old Mar 20, 2020 | 09:58 PM
Redvette2's Avatar
Redvette2
I don't know about deleting...I bought my C3 two years ago and have learned so much even from the old threads. I would rather see a flashing indicator of some kind to notify us when the post is over so many years without any reply.
Old Mar 21, 2020 | 12:08 AM
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Agreed, I learn a lot when searching threw old threads
To 74 L82 overheating issues, need help
Old Mar 21, 2020 | 05:32 AM
interpon's Avatar
interpon
Agree too...im new less than a year...
with that said if the moderators could set the default to not scroll into old threads that would go a long way to help..
also for whatever reason i get much better guidance from google to corvette forum than searching the forum itself..
Old Mar 21, 2020 | 10:12 AM
Dcott's Avatar
Dcott
Cruising
Originally Posted by lars
Dcott -
it was an honest mistake I was attempting to reply in my new topic but well read right on through mine into this one
Old Mar 21, 2020 | 12:22 PM
KenSny's Avatar
KenSny
Go to USER CP and EDIT then change the Related Thread option, and this will not happen when you are signed in.
