small annoying problem with shifter knob
Jun 27, 2002 | 01:04 AM
small annoying problem with shifter ****
when my revs are up past 3000, especially in 4th, my shifter **** wiggles itself loose and i have to screw it back on. i've torqued on it as much as i can and it still comes loose. any ideas?
Jun 27, 2002 | 01:05 AM
Re: small annoying problem with shifter **** (SizzleChest)
Loctite Blue or if you never ever ever ever want it of go with the red
Jun 27, 2002 | 03:47 AM
Sounds like your threads are rounded and not holding well enough. You might want to try a tap & die and clean the threads. Wrapping the shaft threads with teflon tape might help.
Jun 27, 2002 | 03:59 AM
Re: small annoying problem with shifter **** (Rockn-Roll)
Jun 27, 2002 | 06:28 AM
Re: small annoying problem with shifter **** (inferno-vette)
I put a nut on the shifter first and then put the ball where I wanted it, then tightened the "jam"nut. No problems and the "H" patern is straight. :D
Jun 27, 2002 | 08:58 AM
Re: small annoying problem with shifter **** (silvervetteman)
Take it from me, buy a Hurst. It brings driving to a new level.
Jun 27, 2002 | 10:26 AM
Re: small annoying problem with shifter **** (Paul 75 L82)
I agree with both comments.
Jun 27, 2002 | 10:30 AM
Re: small annoying problem with shifter **** (subboz)
But put very little on, so you can remove it if you need to in the future.
Jun 28, 2002 | 03:59 AM
actually the teflon tape worked pretty well. i had thought about it before i made the post, but i thought it would need something more. thanks all!
Jun 30, 2002 | 11:47 AM
Try a dab of silicone cement. Let it dry overnight and your problem will be fixed.
