Please help!!!
Old Jul 9, 2013 | 08:06 PM
PONYUP's Avatar
PONYUP
8th Gear
Default Please help!!!
HELPPPPP!!! im am wore out. was doing the rear brakes on my 68 327 turbo 400.car.and wile tighting a bolt on the rear axcel wile in park and on jack stands. something gave. the rear axcel stared turning. oh crap was my responce. so i got in the car and fired it up wile it was still on stands. no tires on the rear. it started in park but made an loud, no a LOUD!! grinding sound. i put it in all the other gears. no grinding sound. so today i droped the trans pan and took a look at the pawl and the gear it locks into they do not look bad. pawl looks realy good, yet wile on stands and me pushing up on the pawl to make sure it holds gear inplace. i can still roll the tires with my foot. and thoughts. sencerly tired,deflated and plum wore out.
Old Jul 9, 2013 | 10:08 PM
roadblock69's Avatar
roadblock69
I hate to point out the obvious but, How can you see the parking pawl from a pan removal? I only see a valve body when I remove the pan. That being said. You should not run your car on jack stands as the U-joints are hyper extended, that does them no good. You may not have had the pawl set in its home or you have one bad slot in the hub that captures the pawl. That is about all I can say but, don't worry, put it together and see what develops going forward.
Old Jul 9, 2013 | 10:15 PM
TimAT's Avatar
TimAT
Any metal in the trans pan? Follow the rod that runs down the left side of the trans and make sure the 2 bolts that hold the guide for the parking pawl are tight. With a light, you can look and see if the pawl is engaging the ring on the rear planetary that locks it into park. It's right above (looking up from the bottom) the guide plate.
Old Jul 9, 2013 | 10:29 PM
wombvette's Avatar
wombvette
One wheel will rotate even with it in park with the wheels off the ground. Its just turning the spider gears and the clutches if posi equipped.
Put it on the ground and drive it.
Old Jul 10, 2013 | 11:59 AM
PONYUP's Avatar
PONYUP
8th Gear
thank guys. I have always been a car guy. but this is my first vent. many lessons yet to learn.
Old Jul 10, 2013 | 01:50 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by PONYUP
...I have always been a car guy...
Have you told your parents?
Old Jul 10, 2013 | 02:41 PM
PONYUP's Avatar
PONYUP
8th Gear
Sorry haven't spoke to my parents in 30 years
Old Jul 10, 2013 | 08:17 PM
hugie82's Avatar
hugie82
That nasty grinding noise was the back wheels still spinning when you put it in park we've all done it but most of us did it when we where teenagers
Come on here before your next project and blow it by the guys! I do it and I've been building cars for 30 years
Old Jul 10, 2013 | 08:23 PM
hugie82's Avatar
hugie82
Also ponyup, it would be a good idea to list where you live (town/ state) in your profile. Many guys, myself included will alway lend a hand and there's always someone on here near by
To Please help!!!
