Small Block 400 Build
Old Jul 10, 2013 | 04:00 PM
shua1269's Avatar
shua1269
Default Small Block 400 Build
Here's what I have:
sbc 400 (509 Block 2bolt main)
fresh bore(.030) and hone
flat top srp pistons
6" rods
callies stealth crank Shaft.
I the opportunity to get a new crane cam PN: CC-320A-NC for super cheap. Description from Jegz says RPM 5000-8600; Adv. Dur. 320 Int./Exh.; Valve Lift .599 Int./Exh.; Lobe Angle 108 deg.; Jegz part number 114721
I also have access to a weiand team-g single pane intake.
What Heads should I go with this set up? Should I find a different cam? Different Intake?
Old Jul 10, 2013 | 05:04 PM
MelWff's Avatar
MelWff
what are you trying to do with the car? what transmission? what rear end gears?
Old Jul 10, 2013 | 05:07 PM
shua1269's Avatar
shua1269
I want it for a weekend cruiser and occasional strip time. I am going to swap my 3speed with a 700r4. and it has the stock 3.36 gears. I want a lot of torque to make it fun.
Old Jul 10, 2013 | 05:18 PM
augiedoggy's Avatar
augiedoggy
Well that cam isn't going to do it for you.... it doesn't make power until your reving the the moon..... that cam is best suited to a high stall converter and 4.56 gears. Is that rpm range even right? 5000- 8600?? Must be a mistake? That's beyond the useful rpm range of your gears entirely.
Stick with something in the 268- 274 range for street torque and fun at the stop lights....you need the power to start coming in below 2,000 rpm.
Old Jul 10, 2013 | 05:28 PM
shua1269's Avatar
shua1269
Awesome thanks. Any input on heads or intake?
Old Jul 10, 2013 | 06:54 PM
hugie82's Avatar
hugie82
A duel plane will work best and stay under the hood.
2.02 or 2.05 aluminum heads with 68cc chamber will be a nice fit too..
Cam, I would try to stay under .220 duration @0.50 for street ability!
I hope you changed out your main bolts for ARP studs on that 2 bolt main???
Old Jul 10, 2013 | 09:13 PM
augiedoggy's Avatar
augiedoggy
I was talking advertised duration like the OP posted... and the 400 2 bolt has been known to hold up better than the 4 bolt. Not that the studs won't help.
To Small Block 400 Build
