BBC 396 from sick solid roller to hyd Roller EFI...
Old Jul 11, 2013 | 01:07 PM
Cstraub69's Avatar
Cstraub69
Default BBC 396 from sick solid roller to hyd Roller EFI...
Customer's customer had a mint Nova that was his baby but the complaints of fuel smell, bucking in high gear at low rpm, and hard starting had him hating the car. The engine was a BBC 396 + .040" with a set of '69 model factory closed chambers. The car had a custom solider roller .5XX/.6XX 243/251 .050" on a 112. The engine builder wanted to go hyd roller and did not care if we lost a little power going to a hyd roller as the customer wanted driveability.
So the engine builder dyno'd the engine as is. Made 510HP at 6000 rpm and 446#/ft at 5000 rpm. He left timing, carb, and everything as is and put in a Clay Smith 160-3101 with a set of the Morel Street lifters. Engine made 520.9HP at 6200 rpm and 476#/ft at 5000 rpm.
He then put on the atomic EFI system and began to tune. The end result was 550HP at 6500 rpm and 510#/ft at 5900.
It idles, it starts, it rpms, and the engine builder says it is a totally different car now. Not shabbby out of a 396!!!
Old Jul 11, 2013 | 01:36 PM
Big Block Dave's Avatar
Big Block Dave
Things like this impress and amuse me at the same time. I dont think anyone thought for a second that the hyd roller would produce more power with all things being equal.
With that said, do you feel that these results are related to one cam profile being superior to the other, OR the profile of the cams with respect to the cubic inches.... ie, if this was a 454 would that solid roller now work to its potential and produce more power than the same hyd roller?
Old Jul 11, 2013 | 02:00 PM
Cstraub69's Avatar
Cstraub69
Dave,
Its all about building a combination based on what the customer wants to do. I have always said the right cam will make more power than the wrong cam no matter what it is.
Now the EFI making that kind of power. That surprized me but I am a carb guy.
Old Jul 11, 2013 | 02:16 PM
Big Block Dave
The EFI took me a little by surprise too, because the gains were huge!
I know you are kind of a magician with this sort of thing..I think you recently set up a team chevelle friend of mine from CT with a reground solid roller that started out as a ZZ502 grind. He and I talk about low compression 454 builds...curious about what you would slap into a stock LS4, 4 speed car
Old Jul 11, 2013 | 02:20 PM
Cstraub69's Avatar
Cstraub69
I'll be shot for this but compression doesn't factor in to camshaft duration or lift. I can manipulate Events to help but simply put a compression 454 or a low compression 454 with all things equal will need the same amount of lift and duration to make power in the given rpm range.
Old Jul 11, 2013 | 02:24 PM
Big Block Dave
The conversations my friend and I have had about this subject yielded pretty much the same answer Just curious if there would be a grind you would lean toward
Old Jul 11, 2013 | 02:26 PM
Cstraub69's Avatar
Cstraub69
Post the build, rpm range you want power and I will look at it.
Old Jul 11, 2013 | 02:33 PM
Big Block Dave
Thank you sir!
As of now the motor is bone stock [or at least I believe it to be], so it shooooould be a 8.25:1 454. I have an edelbrock performer that has had the runners hogged, an 800 spreadbore dp, and a set of 1 7/8" headers sitting around waiting to become part of the package.
Trans is an M21 built as an M20, and I have a 3.55 pumpkin ready to replace my 3.36 rear.
Id like the car to have good useable power from as close to idle as possible, to about 5k. Yes, I know this range is almost laughable, but its where I see myself with this car. Once upon a time I had a 454 that went to about 6400 with a comp 306s, 4k stall, and 4.10s...that was then and this is now
Thanks for any tidbits of advice or direction you could point me in!
Old Jul 11, 2013 | 02:36 PM
Cstraub69's Avatar
Cstraub69
What head casting number?
Old Jul 11, 2013 | 02:44 PM
Big Block Dave
Im completely embarassed right now and feel like an amateur for saying this, but I havent pulled a valve cover in the 3 years of ownership, as I have tended to all sorts of other nonsense on this car in that time. I know I shouldnt assume that they are 781's, but thats what shouuuuld be there.
How about this...I have an ignition project coming up soon on this car [just threw my msd in the pass dash panel and putting in msd dist soon]...at that time I'll pull a cover and shoot you a PM?
Old Jul 11, 2013 | 04:10 PM
Cstraub69's Avatar
Cstraub69
For the boards sake....assuming 781's and a max of 5000 rpm:
Hyd Roller
600/570
219/223
109 Lobe Sep
Old Jul 11, 2013 | 04:17 PM
Big Block Dave
I appreciate you taking the time, and apologize for not having all of the necessary information on hand.
Old Jul 11, 2013 | 04:41 PM
Cstraub69's Avatar
Cstraub69
No apologizes. All I have done is cams today so 1 more is no biggie.
Old Jul 11, 2013 | 04:59 PM
zwede's Avatar
zwede
Hyd Roller
600/570
219/223
109 Lobe Sep
I'm curious about using less lift on the exhaust compared to the intake. In the old days the exhaust had more duration and lift, now they still have more duration, but less lift. How come?
Old Jul 11, 2013 | 05:52 PM
Cstraub69's Avatar
Cstraub69
To be discusssed tommorrow.
Old Jul 12, 2013 | 12:08 PM
Cstraub69's Avatar
Cstraub69
Cam lobes are designed in families. If a family started at say 230@.050 it may go to 248@.050". The lifter velocity rate stayed the same, so naturally the larger lobes had more lift.
My "cam beginnings" started from John Reed. John started mixing families of his profiles in the 70's. Intake tract and exhaust tract do not operate in any capacity alike... depression.....high pressure. The lobes should not be the same. On exhaust as soon as you crack the valve the exhaust wants out. Time (duration) is what the exhuast port needs and based on how good the port flows, less time for a good port more time for a bad port, is what is important. Lift, hell it just is there.
Old Jul 12, 2013 | 01:40 PM
zwede's Avatar
zwede
Interesting. How about a turbo, would that change anything?
Old Jul 12, 2013 | 04:20 PM
Cstraub69's Avatar
Cstraub69
Whole different story...
Old Jul 12, 2013 | 09:47 PM
zwede's Avatar
zwede
Tomorrow?
To BBC 396 from sick solid roller to hyd Roller EFI...
