engine code
Old Jul 12, 2013 | 07:16 AM
corvette3's Avatar
corvette3
Default engine code
Hi guys
i have a 1972 coupe
the engine i have is not matching im trying to find out which year engine it is and if it is a vette engine
code is : CE3275
thks
Old Jul 12, 2013 | 08:31 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
CE indicates a replacement engine block, usually done under warranty. The block casting number will help with determining displacement.
Old Jul 12, 2013 | 10:03 AM
corvette3's Avatar
corvette3
CE indicates a replacement engine block, usually done under warranty. The block casting number will ehlp with determining displacement.
thanks mike
then will my car hold the same value as a matching number or less,
the engine is weak and im considiring rebuilding the engine or better buy a new engine
thks
Old Jul 12, 2013 | 12:57 PM
Easy Mike's Avatar
Easy Mike
Originally Posted by corvette3
...will my car hold the same value as a matching number...
No. You car had only one original engine and it has been replaced.
Love her for what she is.
Old Jul 12, 2013 | 01:07 PM
corvette3's Avatar
corvette3
Thanks mike
Then i will rebuild the same engine
To engine code
