79 Corvette
Old Jul 12, 2013 | 10:22 PM
jtpie's Avatar
jtpie
5th Gear
Default 79 Corvette
I have just replaced my battery about 3 weeks ago. Went to start car and it was dead. I had some work done to the front and rear suspension would this have some bearing on the starting issue ?
Old Jul 12, 2013 | 10:41 PM
Oldguard 7's Avatar
Oldguard 7
No. It is possible you have a parasitic draw that is draining your battery.
Old Jul 13, 2013 | 01:16 AM
speedreed8's Avatar
speedreed8
2 simple things to check, make sure your interior lights go off about 30 sec. after the door is closed, and check the light in the glove box. there is a switch that the door has to contact to turn it off.
Old Jul 13, 2013 | 01:23 AM
pauldana's Avatar
pauldana
Old Jul 13, 2013 | 01:19 PM
jtpie's Avatar
jtpie
5th Gear
Default 79Corvette
I checked the interior lights and the glove box, all are going off. I am stumped as to why the battery just started to drain completely dead. Any clues would be appreciated, thanks.
Old Jul 13, 2013 | 07:00 PM
1979C3's Avatar
1979C3
I had this problem as well. After changing the battery, I talked to some folks who work on just Corvettes...they said this is a common ailment for our Vettes, I can't vouch to that either way. So decided to put in a cut-off switch on the battery. When it's parked for more than a few days, I disconnect the battery. Haven't had a problem since, and it's been at least 8 yrs.
Old Jul 13, 2013 | 07:16 PM
Kacyc3's Avatar
Kacyc3
My car did this it was a result of the dome light switch in the door shorting out and causing the antitheft to drain the battery. I disconnected that relay and problem solved till I get door switches
Old Jul 13, 2013 | 09:58 PM
speedreed8's Avatar
speedreed8
i recently had the same problem, the diodes in the alternator were bad, slowly draining the battery, rebuilt alternator,,, diodes and voltage reg., fixed. you can put a test light between your neg. cable and the battery post (light should come one),and pull fuses one at a time, until the light goes out, to determine where the drain is coming from. i had to remove the charge wire on back of the alternator thats how i was able to find mine.
Old Jul 13, 2013 | 10:04 PM
pauldana's Avatar
pauldana
, the diodes in the alternator were bad, slowly draining the battery, rebuilt alternator,,, diodes and voltage reg., fixed. y.
lol... that happened to me also... but i never heard it happening to anyone else....until now...
To 79 Corvette
