chrome bumper replacements
Old Jul 13, 2013 | 06:16 PM
wpmjr's Avatar
wpmjr
Default chrome bumper replacements
Corvette America's bumper replacements seem reasonably priced- are they just chrome plated?- the originals seem to be solid chrome. Am I better off trying to get the small rust pits somehow taken care of and the old ones re-chromed?
Also- where do i buy body lift straps?
Old Jul 13, 2013 | 06:20 PM
7t9l82's Avatar
7t9l82
no such thing as solid chrome. it is all plating, just different quality
Old Jul 13, 2013 | 06:43 PM
wpmjr's Avatar
wpmjr
that sounds reasonable, I'm just surprised the original doesn't flake off like other chrome pieces I've seen decay
Old Jul 14, 2013 | 12:58 AM
starr69's Avatar
starr69
If you get them re-chromed; VirginiaVettes was the best pricing that I found.
Old Jul 14, 2013 | 08:53 AM
1974ta's Avatar
1974ta
Default bumpers
If you get them re-chromed and you are a perfectionist, spend the money for a top of the line chrome shop. Librandis is the one a lot of corvette guys use.
Bill
Old Jul 14, 2013 | 10:09 AM
wpmjr's Avatar
wpmjr
I'd rather hear that the quality of the replacements is wonderful and I should run with that. Rechroming is only if the replacements are thin crap that start to peel the day after the warranty is out...
Old Jul 14, 2013 | 10:25 AM
Alan 71's Avatar
Alan 71
Hi wpm,
Librandi's in Pennsylvania has been doing chrome plating for car and motorcycle lovers for many years and do beautiful work as Bill mentioned.
They respect their customers and have reputation to protect by continuing to do exceptional work.
The chrome plating they did for my car is more than 10 years old and is still flawless.
Check them out!
Regards,
Alan
Old Jul 14, 2013 | 10:40 AM
Ironcross's Avatar
Ironcross
Send yours out to be plated as the repos or rejuvenated ones will probably not fit your Vette properly or as good as your OE bumper
Old Jul 14, 2013 | 01:08 PM
bhk2's Avatar
bhk2
and it may be cheaper to re-chrome them than purchase the off-shore replacements. Just had my bumper re-chromed and one of the factors in my decision was I was guaranteed a good fit.
Old Jul 14, 2013 | 01:53 PM
wpmjr's Avatar
wpmjr
Well one piece has a small dent, another had 2 big holes drilled in it, and one is rusted through in a spot. CA sells both import and USA replacements, and it appears only the imports warrantee the finish (for 5 years). I think I'll buy a replacement for the one with holes in it and judge the fit and quality of that piece before buying more. It doesn't sound like anyone with actual experience with the CA products has chimed in...
Old Jul 14, 2013 | 03:13 PM
edk136's Avatar
edk136
Which bumper had the two big holes drilled in it? If it's on the bottom of the front bumper, it may be the original holes from the factory.
Eric
Old Jul 14, 2013 | 03:32 PM
Alan 71's Avatar
Alan 71
Hi Eric,
Paragon Corvette Reproductions is selling bumpers made on the original GM tooling if that's of interest to you.
Regards,
Alan
Old Jul 14, 2013 | 04:04 PM
ddawson's Avatar
ddawson
Is there a way to tell if you have originals or reproduction?
Old Jul 14, 2013 | 04:51 PM
wpmjr's Avatar
wpmjr
Eric: These holes are on the LH rear bumper and are obviously hand made.
Alan: Thanks- I'll check them out!
dd: It's a '70 we've had since '74, so I have a strong belief these are original
Old Jul 14, 2013 | 05:43 PM
Roco71's Avatar
Roco71
Originally Posted by Alan 71
Hi Eric,
Regards,
Alan
My front bumper is a reproduction from Pargon and it fits perfect and looks outstanding.
Old Jul 14, 2013 | 06:36 PM
edk136's Avatar
edk136
Hi Eric,
Regards,
Alan
I was trying to help the OP possibly identify the holes that were drilled into the bumpers but since you brought up Paragon and they have the original GM tooling, would this also apply to the front bumperettes? I will be shopping for those soon.
Eric
Old Jul 14, 2013 | 07:20 PM
Alan 71's Avatar
Alan 71
Hi Eric,
The Paragon catalogue describes the bumpers but not the bumper-ettes.
I'd give them a phone call to clarify.
Also, the bumper-ettes have a section that is painted to match whatever paint is used on the egg crate part of the front grills. So that finish will need to be matched.
Regards,
Alan
Old Jul 14, 2013 | 10:55 PM
edk136's Avatar
edk136
Hi Eric,
Regards,
Alan
I have heard Paragon has the best fitting "aftermarket" bumperettes and it could be true IF they have the GM tooling to reproduce the bumperettes. I wish I could re-chrome mine but they're too far gone. I'll have to do more research when I get closer to tackling that project.
Eric
Old Jul 15, 2013 | 09:40 AM
Alan 71's Avatar
Alan 71
Hi Eric,
The fit of the bumper-ette can be difficult but I believe it usually has more to do with it's upper connection at the bumper and then it's lower connection at the bottom bracket that attaches to the front crossmember, rather than how it was made.
Also, the way the grills are mounted have a LOT to do with how the gap between the grill and bumper-ette lines up and how big the gap was.
Ideally there should be very little gap and the alignment with the grill should be straight. Unless the fiberglass, crossmember, or brackets are 'tweaked', a good fit is obtainable. This is why it's often a good idea to trial fit the the bumpers and GRILLS before painting so that if the the grills need to be moved a little the fiberglass can be 'adjusted' if necessary.
The exterior of the car is rarely easy!
Regards,
Alan
To chrome bumper replacements
