pipes
Old Jul 14, 2013 | 10:27 AM
rays699's Avatar
rays699
Default pipes
I have a ? for any one I have a 69 bb vette with side pipes + on the right side it pops at a idle, but not on the left side, the pipes are 4 into 1 xs power it did this before out the back.
Old Jul 14, 2013 | 11:05 AM
augiedoggy's Avatar
augiedoggy
I could be wrong but If you dont have an exhaust leak Sounds like one side of the engine is running too lean.... dose your Carb have separate idle screws for each side? If so try turning the screw out in 1/4 turns keeping track of the position until it stops.... xs - power were the first company to market the later obx branded pipes the header flange is very thick and very unlikely to warp and leak.... but it wount hurt to look for a leak there and check bolt tightness...
Old Jul 14, 2013 | 03:29 PM
terrys6t8roadster's Avatar
terrys6t8roadster
stock distributor? points? my 68 popped all the time. MSD no more ignition misfires.
Old Jul 15, 2013 | 10:21 AM
rays699's Avatar
rays699
Default pop
I just installed all msd complete ignition, dis, 6al box, coil+ wires, holley d pumper 850,set all idle screws with vacuum gauge. just put on the pipes + checked heads + flange to be clean + flat. it poped with the stock manifolds on it .
Old Jul 15, 2013 | 05:09 PM
augiedoggy's Avatar
augiedoggy
What kind of shape is the timing chain in?
Old Jul 16, 2013 | 09:33 AM
rays699's Avatar
rays699
Default pop
timing chain is in good shape, if it jumped some teeth it wood pop on both sides pipes or not?
Old Jul 16, 2013 | 10:14 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
Do you still have the heat riser on the passenger side? If you do check it for smooth operation. Sometimes they get stuck and will choke exhaust flow on that side.
Old Jul 16, 2013 | 10:50 AM
rays699's Avatar
rays699
Default pop
I am running headers+side pipes 4 into 1, no heat riser.
Old Jul 17, 2013 | 08:53 AM
scrappy76's Avatar
scrappy76
Was it popping before you did the wires,plugs ?
Old Jul 17, 2013 | 11:22 AM
rays699's Avatar
rays699
Default pop
yes, it was popping out the back before the headers + side pipes
To pipes
