1972 Gas Gauge Issue
Old Jul 14, 2013 | 01:13 PM
rosseich's Avatar
rosseich
Default 1972 Gas Gauge Issue
My gas gauge is not accurately registering the correct fuel level. I recently completed a frame-off restoration so the sender and wiring are new but the gauge is original (it worked prior to the restoration). What is the most-likely cause? How can I diagnose the issue?
Thanks.
Old Jul 14, 2013 | 01:31 PM
Alan 71's Avatar
Alan 71
Hi r,
The Willcox site (listed on the left side of this page) has a section for installation and trouble shooting help.
There's a listing for testing the gas gauge and sending unit to determine what the problem may be.
You might want to read over that information.
Since your car has been apart might it be a grounding problem at the gauge or sending unit?
Good Luck!
Regards,
Alan
How about some pictures of your 72 (after you get your gauge problem settled)?
Old Jul 14, 2013 | 03:50 PM
rosseich's Avatar
rosseich
Thanks for the referenced information. Here's what I found. My sending unit is putting out about 30 Ohms when the tank is 1/2 full so it appears to be about 15 ohms low (90 ohms is full so 45 ohms is 1/2 tank).
Does anyone have any ideas?
Thanks.
Old Jul 15, 2013 | 11:09 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
You may have bent the float installing the sender, or it was bent when sent to you.
You can bend the arm to make adjustments too. Just make sure the arm is at 45 ohms when you are 1/2 way on the throw.
Willcox
To 1972 Gas Gauge Issue
