Fuel Smell
Old Jul 15, 2013 | 02:09 AM
SGTCrowley's Avatar
SGTCrowley
Default Fuel Smell
Just got a 1979 Corvette on Craigslist. It has a full tank. I went out driving to test a new performance thermostat and I got a strong fuel smell coming from the rear, outside and inside, after running it.
What are common trouble spots for vapor leaks/fuel leaks on these cars?
I get REAL nervous when I smell gas!!!
Old Jul 15, 2013 | 06:45 AM
rbowman's Avatar
rbowman
If its coming from the rear of the vehicle after a drive it is possible the rubber fuel lines in the tank area are leaking.
Ron
Old Jul 15, 2013 | 09:11 AM
Alan 71's Avatar
Alan 71
Hi sgtc,
Since you mention 'full tank' you might also want to check the gasket on the gas cap. There might be enough 'sloshing' around to leak some out the cap.
The hoses Ron mentions could certainly be the source too.
Regards,
Alan
Old Jul 15, 2013 | 10:34 AM
SGTCrowley's Avatar
SGTCrowley
Originally Posted by Alan 71
Hi sgtc,
Regards,
Alan
Thanks, ...I found a good thread on the sending unit Gasket, I'm just not sure how to access those lines and/or the sending unit?
I need a good repair manual. From diagrams on a Google search it looks like the gasket, and lines are on the top of the tank, so the tank must be dropped down for access?
I have a full tank of gas too! I'll just have to drive it and keep an eye on it.
I have full coverage, $500 deductible and a Fire extinguisher... so I should be good!
Old Jul 15, 2013 | 10:41 AM
qwank's Avatar
qwank
how did the performance thermostat work out?
Old Jul 15, 2013 | 12:24 PM
78SilverCam's Avatar
78SilverCam
Ron
I had the same issue. First step is to replace all rubber fuel hoses at the gas tank, fuel pump and Evap Cannister. You can do it unit by unit but if they are all the original hoses - I would replace them all anyway.
I am willing to bet your problem will go away once that is done.
Of note, the fuel pump hose is "S-shaped". Either carefully bend a normal hose so that it doesn't kink, or get a replacement from Corvette Central or (your preferred vendor X).
Old Jul 15, 2013 | 01:48 PM
SGTCrowley's Avatar
SGTCrowley
It's helped, a lot, I think? I drove it last night, Phoenix got a little rain, so it was a nice drive. Ran fine. Then, this morning I drove down to my school's finical aid office. The Outside Temps were between 90 and 95 Fahrenheit. I took the T-Tops off for the first time. It ran very cool (a lot of heat at my feet and no AC, yet)
But, when I changed the T-Stat, the fluid in the radiator looked like 50% water and it stunk like a sewer!! So as soon as I get some extra cash, I am going to have Firestone flush the engine and radiator!
I can accept donations at www.HeroRanch.com LOL!!!
Eventually, I plan to put in a High Performance radiator and water pump on it. I do live in Phoenix!
Old Jul 15, 2013 | 07:08 PM
gcusmano74's Avatar
gcusmano74
If you are running a stock or nearly stock engine the factory cooling system will work just fine. Disregard for racing and high HP applications.
To Fuel Smell
