Radio/electrical issue?
I've got this weird problem happening with the radio in my car, and I'm not sure what exactly is going. Basically, it goes like this. I installed a radio in my car back in April, and probably drove 500 miles with it this spring, worked great. Fast forward to May, due to a fluid puddle on the floor I decided not to drive it until I had time to look at it. Finally, about 2 weeks ago I had time to look at it, battery completely dead (been sitting 4 to 6 weeks). Charge it up, car starts fine, no issues at all, but I notice my radio was turning on and then turning itself off (retrosound unit). Yesterday I took it out again, started up fine (been sitting for two weeks) and the radio would play for like 30 seconds, then reboot, then play for 5 seconds, then turn off for a minute, then come back on for a little bit, etc.
My battery is a 4 year old Optima red top. My question is:
a) is this a battery problem?
b) is this an alternator problem?
c) is this a radio problem?
Because I'm not exactly sure. I know that the C6's flake out when the battery gets old, wasn't sure if my radio (since it's based upon new technology) wasn't getting fed bad voltage or something. Was hoping that someone else had a similar experience sometime and could lend some insight. Thanks! About the only thing I could think of to do would be to measure the voltage at the battery, see what it's putting out.
Could be a short in the switched power wire somewhere. Does the radio maintain it's setting when car is off?
If wiring looks good, it could be the radio.
So I'm about 95% sure it's the radio, as it's obvious that it's getting power.
Had the same mystery issue with an aftermarket stereo.
Worked, stopped, worked, stopped. No apparent reason.
Troubleshooting eventually produced a bad inline fuse. Cheap fuse cap had come loose from the filament. Sometimes it made contact and others it did not depending mostly on how hot or cold the filament got. Got lucky when troubleshooting and simply wiggled the hot wire with the inline fuse and viola the radio started working.
If the battery isn't "working", measuring its voltage rarely tells you anything (unless complete cells are dead).
Is there any way I could measure anything while in the accessory position (amps maybe)? The voltage drops about .1 when I'm in that position and trying to run the radio. I would think that there would be something I could measure, since in that position the radio is basically the only thing going.
However, it's still flaky when driving. I have determined though that accelerating hard will make the radio flake...which means that it's probably the alternator that's the issue. Probably a logical guess? The volts when driving are 13.5, accelerating though does not seem to increase the voltage. I can't think of any other reason the radio would die when accelerating other than the alternator.
Bad connection somewhere or its the radio. Check the fuse but also double check the fuse holder and clean the holder where it connects to the fuse. I had an intermittent brake light problem one time and I kept checking the fuse with a test light which always showed good. It was the pressure I was putting on the end of the fuse with the test light that was causing it to make good contact. Once I cleaned the fuse holder, I solved my problem.
I am assuming you are using the factory wiring and the fuse in the fuse box. If you wired out an inline fuse for the radio, double check that fuse holder and double check where the wire is tapped into for power. If it's tapped into the fuse box, check that connection.
Some people have had problems with how the fuse box connects to the wiring harness. There is a bolt that holds the the two together in the engine compartment. It could be loose. Or the connections inside could be corroded or loose and requiring attention. Do not pull the harness apart from the fuse block without first disconnecting the battery.
DC
DC
