New leaf spring?
Old Jul 16, 2013 | 07:34 PM
havesometo's Avatar
havesometo
Default New leaf spring?
I'm installing a new leaf spring with poly bushings. The old springs have cups on the ends do I need to remove those install them in the new spring?
Old Jul 16, 2013 | 08:19 PM
Alan 71's Avatar
Alan 71
Hi hst,
You could remove them and transfer but the cups are readily available new so you might want to order some.
The cup is pretty easy to install using a small hammer to peen over the cup's flange.
Regards,
Alan
Old Jul 16, 2013 | 08:43 PM
havesometo's Avatar
havesometo
Thanks alot Alan. I will order some new ones. I didn't know if I needed them on there are not with the poly bushings.
Old Jul 16, 2013 | 08:50 PM
MakoJoe's Avatar
MakoJoe
I could not find just the caps in my parts search and eventually I will be re-doing my Springs in the front and rear end. But it a project I will get into next year or the year after.
They do sell a bolt kit with Poly bushings if you choose to replace just the bolts and caps.
http://www.ecklerscorvette.com/corve...1963-1982.html
If you wanted all new bolts in the rear end they also sell a kit for this.
http://www.ecklerscorvette.com/corve...1969-1977.html
Old Jul 16, 2013 | 09:49 PM
havesometo's Avatar
havesometo
Thanks MakoJoe.
To New leaf spring?
