clutch adjustment question
Old Jul 17, 2013 | 04:25 PM
Belgian1979vette's Avatar
Belgian1979vette
Default clutch adjustment question
I've been fighting some clutch and shifter issues since I have had my car on the road, nothing bad, but I was trying to get rid of some of the issues, but don't seem to get there.
When I bought the car it had a Muncie M22 with an original bellhousing. The clutch rod was an adjustable type and the clutch fork wasn't original to the car.
When I did my restoration, I had to buy me a new flywheel and I bought a Mcleod SFI steel flywheel. I changed to a explosion proof bellhousing from Lakewood in the process. The clutch remained the centerforce gold one that was on the car when I got it, since it was in almost new condition.
I bought a new clutch rod and fork, correct for my car and its transmission.
Now for the issue : when I adjust the clutch as per factory specs (as stated in the manual : .400 of clearance between the back nut and the swivel) the clutch only engages when I'm almost at the floor with the pedal. I put the nut closer than .400 to the swivel and it seemed to improve things, but I seem not to disengage enough. It almost seems like I need some sort of different rod length. Anyone encounter this. Could this be in the thickness of the flywheel. I remember that the Mcleod was bulkier than the original...
Old Jul 17, 2013 | 05:03 PM
gkull's Avatar
gkull
once you start changing things the stock setup is just a rough guide.
The length of the pivot ball in crutial to have it work correctly.
I have a non-stock setup myself and my only adjustment is the nuts on the rod that comes through the fire wall to the top of the "Z" Bar.
But anyway if you are out of adjustment thread the real cure is changing the length of the pivot ball or the length of the lower "Z"Bar to clutch fork.
i just had mine all apart to change heads and I over did it and It dissengages in the first two inches of travel and I have very little clearance between the throw out bearing abd the clutch plate fingers
Old Jul 17, 2013 | 05:24 PM
Belgian1979vette
G, should have mentioned this, but I measured the pivot ball height and compared it to the one in my Original bellhousing and it's was spot on. Could this be something else ?
Old Jul 17, 2013 | 06:29 PM
gkull's Avatar
gkull
If you have a thicker flywheel and or PP assembly it would place the throwout bearing closer to the fingers. Which would cause the clutch to disengage sooner with less petal movement.
Over the years I have seen cut and welded longer lower arms and even ones with a threaded centers and turnbuckles for length adjustment.
The big thing about the pivot ball is you want to hold the fork/bearing at 90 degrees to the input shaft when you are in the static rest position. So the bearing center has little or no drag on the tranny input shaft. As you depress the clutch petal the fork arm swings in an arc and it causes shaft friction. You want to minimize the arc.
So a longer pivot ball would place the TB closer to the fingers. Or on the other side the thicker flywheel would do the same
Old Jul 18, 2013 | 10:34 PM
iokepakai's Avatar
iokepakai
Using the Speed Direct clutch linkage..Smoother and has a greater range of adjustment...
[IMG][/IMG]
http://cmc.speeddirect.com/items.asp...atus=0&Tp=&Bc=
Old Jul 19, 2013 | 03:08 AM
Belgian1979vette
Thanks for that.
Must say that the fork sits as good as 90° to the plate. Don't know, maybe there is something else wrong.
Old Jul 22, 2013 | 12:48 PM
voscreature's Avatar
voscreature
Hi,
Hmm, we have a similar problem I think. See my thread:
http://forums.corvetteforum.com/c3-t...placement.html
I still have not sorted out this fully. But it appears as some of the aftermarket clutches has a pressure plate finger design that is not optimal for the Corvette clutch mechanism. My "original" clutch, brand unknown, releases quite good. The Sachs kit was total disaster, exactly as you described, the LUK kit had a warped pressure plate, otherwise I think that would have worked OK.
Martin
To clutch adjustment question
