balencer alignment
Old Jul 18, 2013 | 03:07 PM
4 speed's Avatar
4 speed
Default balencer alignment
can you check if a balancer is correctly aligned by the position of the keyway compared to the timing mark ?
Old Jul 18, 2013 | 03:27 PM
Peterbuilt's Avatar
Peterbuilt
Yes, the key way is offset 10 degrees CC from the timing mark.
Old Jul 18, 2013 | 03:43 PM
atthemattin's Avatar
atthemattin
Like the guy above me said. If you have a rubber seal around the dampener, you can get a bad read. Overtime the stock ones can slip and throw off your timing marks.
To balencer alignment
