I had a 65 fuelie back in the day . It had what they called off road exhaust, not sidepipes. Any body know part # or if there is something similar out there today. Pretty unique sound
Chambered? Are the "off-road" exhaust systems not just straight pipes w/ very low restriction mufflers? Off-Road meaning not legal in some states due to certain state exhaust restrictions, yes? I know that in the '60s, chambered (mufflers) exhaust systems were offered on some of the performance cars, and they had a neat sound. I've also seen "off-road" systems f/ sale by aftermarket companies that were simply straight pipes w/ very low restriction mufflers, which also had a tough sound, but different from that "chambered" sound.
I don't know the answer to the OP's question. But I do know the answer to yours, and it's "no."
I also know that it's important that everyone have the same understanding of the words and terms we use. I'm not as smart as a lot of these guys, so I have to at least keep the terminology straight.
So..."straight pipes" are just that--NOTHING inside them--just an open pipe.
Mufflers have some type of baffling system in them.
Therefore, if one has "straight pipes" they do not have "mufflers" or "baffling"--of any type. The two are mutually exclusive.
So you heard of these mufflers which look stock from the outstide. I think the had less baffles or none. Had a friend who took the stock mufflers and inserted a crowbar in side and chewed up the baffeles. He came close to duplicating that sound , oh well thanks at least I wasn't dreaming
I hope this helps.
I think you are correct, no baffles have you heard of these mufflers from the past?
I guess if muffler has no baffles is that considered chambered. They had a stock appearance but had a very different sound. wondering if anyone had them
2016 C2 of Year
2015 C3 of Year Finalist
I had the N11 option "off road exhaust" on a 67 427/400 coupe. It was an undercar system that had low restriction mufflers. Alot of people confued the terminology with the factory side mount exhaust N14. I have those on my 65 convertible. Factory side exhaust is louder and the off road was louder than a stock system.
Corvette Central carries the off road exhaust for mid years. I don't know if they have an application for C3's. Most that bought them for their midyears really like the fit, sound and quality. You might give them a call.
I'm honestly not trying to be difficult, but I don't know what you mean when you talk about mufflers with "no baffles." By definition, a muffler has baffles of some sort, be they "glasspacks" or steel baffles.
Unless you're suggesting that someone makes EMPTY "mufflers," with zero baffles, possible to fool state inspections stations?
If that's what you're asking me, no, I have not heard of that.
Again, straight pipes are just that--ZERO flow restriction. Mufflers have baffling/glasspack/some restriction. If empty "mufflers" exist, I'm not aware of them.
The off road option when it was available included larger than stock diameter pipes and lower restriction mufflers.
The aftermarket providers might have a reproduction kit you could use.
*You're exactly right. The off-road system had the less restrictive mufflers and straight pipes, THIS COMBO CONSISTS OF THESE TWO. If I say straight pipes and don't mention mufflers, then that's all there is. And straight pipes w/ mufflers is just that, w/ no resonator or converter. So "FOREVER...," YOU'RE WRONG, NOT DIFFICULT. Chambered exhaust/mufflers are not just gutted mufflers, and infact they're packed and formed to make a tough sound. Look it up and you'll have the correct info.
I have this system on my 1970 L-46 and it sounds fantastic, only loud when you want it to be. Fit is great right out of the box.
This is not a chambered exhaust, nor is it baffleless...the only difference between stock mufflers and N11s is that the former have three baffles in each muffler while the latter have two. The pipes are 2.5".
If I had a 69 I would have sidepipes on it in a NY minute. I even considered them for my 68 big block but it's too original to mess with. The off road sound good but the sidepipes sound BETTER IMO
