I've been fighting with my '79 for about two weeks now. Its had an intermittent rough running problem. I finally tracked it down to the PCV valve. Its letting in enough air to cause the car to run lean. I bought a new one today, but I wasn't able to get the high performance valve, so I bought the one for the base engine. After I installed it - same problem. I assume I have too much cam for the stock PCV valve and don't have enough vacuum at idle to close the valve. I did a search on this forum and found a couple of threads listing PCV valves for high perf engines, but they are all a straight design. The '79 uses a 90 degree valve. The straight ones really don't fit well. Will the PCV valve for an L-82 work any better with an engine that has 13-14" of vacuum at idle, or can anyone suggest a PCV valve that will work for me?
years ago on cars with a lot of crankcase pressure we would use a check valve for a power brake booster.it worked fairly well most of the time .if that helped we would go to a vacu-pan system.the check valve may do it for you.
FYI, pcv valves don't close at idle. They regulate themselves to roughly flow the their same rated amount at any vacuum.
Try one for a smaller engine, 6 or 4 cyl.
Thanks. That's a great thread and I did read it. However the PCV valve listed in the thread is a straight design and doesn't fit well on a '79 engine. I'm hoping to find one with the 90 degree fitting like the original.
Still can't figure out why this problem started all of a sudden. The PCV I installed is the same stock design I have used for 20 years. The carb has been on the car since 2002 with no problems. Suddenly the PCV doesn't work properly. I don't get it.
Tearing out what little hair I have left.
Sounds like a lot of headache from a PCV valve. You are sure this is what the problem is. Should you go back and go thru the process of elimination again? I'm not questioning your mechanical ability, I'm just trying to say that maybe you should re-think the situation, as the PCV seems to be giving you a problem that you never had before f/ an unknown reason. Good Luck w/ this problem. Sincerely, Jimmy.
I'm using the NAPA 2-9216. It shows to be correct for late 60s and early 70s high performance Corvette engines. It is 90 degrees but has two ports. I use the 2nd port to connect my vapor canister.
If you didn't need the 2nd port, I suppose you could always cap it.
Any chance your PCV grommet is old and needs to be replaced to ensure a tight seal with the PCV?
But I would like to express the other side of the coin. No reason to have PVC. The variable vacuum leak plays havoc on any attempt to get correct A/F ratios on any carb.
Piston rings have the most blow by at Wide Open Throttle when the PVC is closed because of loss of vacuum. While cruising at max vacuum you get the max PVC flow and have to run richer jetting to compensate. What are the valve cover breathers doing?
What about a mild (400 hp) 350? Need a PCV valve? This might be my issue as well. Should the whole PCV fitting and "valve" be really tight, or have a little wiggle room?
Believe me, that thought has occurred to me. I've always had a PCV valve but its never been an issue before. I'm starting to think there is an internal problem in the carb causing it to run lean, and disconnecting the PCV is just masking it. I think I'm going to rebuild the carb completely and see what happens.
From: Las Vegas - Just stop perpetuating myths please.
If u don't want to use the intake vacuum u still have other choices. One is using the original type breather only which u can see are standard on GMPP circle track crate engines. Or u can purchase a dedicated vac pump to evacuate the crankcase and install in-place at your smog/AIR pump location (your '79 of course).
And i used to read on line instructions for converting a FORD smog pump into a vac pump for crankcase ventilation - the drag racers would use theese because they have high blowby with only 2 piston rings.
Now the exhaust type evacuation plumbing really only works at open throttle with hi exh flow and not a good option for the street driven car.
Good luck and please post what u find works,
cardo0
No real performance motor runs PVC
not to nit pick but pvc is poly vinyl chloride pcv is positive crankcase ventilation.retired master plumbers are funny about that
