cleaning valves/ pistons, it works!
Old Jul 20, 2013 | 11:58 AM
1977L48's Avatar
1977L48
Default cleaning valves/ pistons, it works!
so when i did my cam swap a few months back, i noticed that my intake valves had a lot of carbon build up, and i could imagine that the pistons were just as bad, so i went up to the chevrolet dealership to see if they had any tips/cleaners to take care of this problem, they recommended the AC Delco top end cleaner to me, they said pour half down the carburetor at a high idle then return to idle and dump the rest down it and let it choke out the engine and let sit for 2 hours. i was a little skeptical on how it would work because i had used seafoam before and couldent tell much of a difference. but i got it, around 30$ and after 2 hours, i started it and ran it hard under a high load and man did it smoke, but once it cleared up man does it run great! i had to re set the timing, idle, and idle air screws, it starts easier and idles better! i went to change the spark plugs today and the old ones had about 1k miles on them and they looked very carbon fouled from all the junk the cleaner knocked loose. the part number is X66-P and it WORKS, i cant wait to see what MPG gains i get from this product.
Old Jul 20, 2013 | 12:07 PM
Mike Ward's Avatar
Mike Ward
No engine in good condition collects carbon that fast. Find out what's wrong with it instead of pouring $30 a bottle miracles in the carb.
Old Jul 20, 2013 | 12:12 PM
1977L48's Avatar
1977L48
The engine is orignal to the car, no rebuild from 1977
Old Jul 20, 2013 | 12:16 PM
Manuel Azevedo's Avatar
Manuel Azevedo
Don't see anywhere said how many miles are on this engine.
Old Jul 20, 2013 | 12:18 PM
1977L48's Avatar
1977L48
Old Jul 20, 2013 | 12:26 PM
Mike Ward's Avatar
Mike Ward
Not relevant. 'Engine cleaners' don't knock stuff loose that sticks to spark plugs.
Old Jul 20, 2013 | 12:31 PM
Manuel Azevedo
I agree but your the one that said,
"No engine in good condition collects carbon that fast"
Old Jul 20, 2013 | 06:08 PM
bpassmore's Avatar
bpassmore
I worked in a Chevrolet / Olds Dealer's shop from 1959-1980 The higher compression engines were especially prone to a ping or rattling noise when accelerated
What I know about the X66-P Top engine Cleaner is it works. In the 60's and 70's when engines developed that "preignition ping" that stuff would eliminate it when used as instructed. It evidently removed something.
We recommended an application about every 3rd 0r 4th oil change and before a tune up.
Old Jul 20, 2013 | 09:21 PM
Mike Ward's Avatar
Mike Ward
You're right- we were forced ti use leaded gas in those days which was responsible for the vast majority of 'deposit'.
But that was then.
Old Jul 20, 2013 | 11:38 PM
1977L48's Avatar
1977L48
and this is now, and i had carbon build up on my intake valves on my L48
Old Jul 21, 2013 | 12:05 AM
Indiancreek's Avatar
Indiancreek
Carbon can be a hard material. being on the intake, it must make it's way through the combustion chamber around the exhaust valve and out. I just hope during that travel, it doesn't scratch the cylinder walls or get hung in the exhaust valves when leaving.
Old Jul 21, 2013 | 12:22 AM
1974ta's Avatar
1974ta
Default Cleaner
From what I have read, the GM product actually soaks the carbon deposits and assists in actually burning off the deposits.
Other methods may result in chunks of carbon that could cause problems.
Google can be our friend
Bill
Old Jul 21, 2013 | 10:18 AM
Mike Ward's Avatar
Mike Ward
To be clear, the above is what I'm taking issue with. Plugs on a properly operating issue don't become carbon fouled and stuff knocked loose by engine cleaners doesn't end up on the plugs.
IOW- if new plugs are fouled after only 1K miles, there's other issued that need to be addressed.
To cleaning valves/ pistons, it works!
