Autogear M-22
Old Jul 20, 2013 | 08:56 PM
Fu-Manchu's Avatar
Fu-Manchu
Default Autogear M-22
Is the Autogear M-22 wide ratio transmission supposed to have that signature whine?
Had one installed in my '70 recently and it doesn't sound noisy at all.
I don't race the car but wanted that "whine".
Anyone know?
Old Jul 20, 2013 | 10:24 PM
roadblock69's Avatar
roadblock69
If it is a wide ratio, it is not an M-22. If it is an M-22 it will whine a little since the helical angle of the gears is less than other Muncie transmissions.
Old Jul 20, 2013 | 11:25 PM
Solid LT1's Avatar
Solid LT1
Regular Muncie has 45 degree gear pitch an M-22 is 22.5 degrees hence the whine. Autogear makes 22.5 degree wide ratio gearsets for the Muncie 4 speed but also 45 degree gearsets are avalible. I would say if it dosent have at least a little whine, you have a 45 degree pitch gearset.
Old Jul 20, 2013 | 11:34 PM
Fu-Manchu's Avatar
Fu-Manchu
So the shop that did the install had the option of specifying which degree of gearset?
Old Jul 21, 2013 | 11:11 AM
ZZ71S's Avatar
ZZ71S
I have a autogear m22w it whiens
Old Jul 21, 2013 | 01:26 PM
Belgian1979vette's Avatar
Belgian1979vette
I have an Original M22. It wines a lot in the first 3 gears and is almost gone when in 4th.
To Autogear M-22
