Wheel Stud Question
Old Jul 21, 2013 | 08:32 PM
starr69's Avatar
starr69
Default Wheel Stud Question
Question: Is 4 1/2 turns (little over 3/8") enough thread for the lug nuts? I marked the lug nut and installed with the wheel on and got 4 1/2 turns. Then I took the wheel off and installed the lug nut 4 1/2 turns and marked and measured it. Didn't want to swap the wheel studs if I don't need to. Thanks
Old Jul 21, 2013 | 08:53 PM
hugie82's Avatar
hugie82
Do you have the correct lugs for the rimes? Some rims the lug will fit throw partially.
Old Jul 21, 2013 | 08:56 PM
starr69's Avatar
starr69
Yes. Rim and lug nut have the same beveled shoulder. Using 1/2 spacer and the studs are stock.
Old Jul 21, 2013 | 09:46 PM
Ibanez540r's Avatar
Ibanez540r
Rule of thumb I have heard is 8-9 full turns, which is usually about a 1/8" spacer max.
Yours may work, or it may not. But to be safe I would go with longer studs.
Old Jul 21, 2013 | 09:52 PM
jyounane's Avatar
jyounane
I suspect others will chime in on this....
My opinion is that this is very dangerous, firstly because you are using a spacer which is just not recommended (or legal in many places) and secondly you may have insufficient thread engagement, and thirdly because the spacer is not providing a hub-centric support / alignment for the wheel.
You should look into wheel (hub) adapters, not spacers. Even with longer studs it is still unsafe IMHO.
Joe
Old Jul 26, 2013 | 05:34 PM
starr69's Avatar
starr69
Ok, I have decided to swap my rear wheel studs. I removed the emergency brake adjuster and cut off the first stud at the 6 oclock position. However it is frozen solid and wont come out. I tried a BFH, a BFH and punch, and driving a chisel under the head all while soaked in penetrating oil. Any ideas on how to get it out?
Old Jul 26, 2013 | 06:13 PM
tektrans's Avatar
tektrans
Heat it-then hit it.
Old Jul 26, 2013 | 08:30 PM
lvmyvt76's Avatar
lvmyvt76
a bigger BFH!
Old Jul 26, 2013 | 09:04 PM
tektrans's Avatar
tektrans
Hate to say but you may have to get it out of the car and put it in a press/vise.
Maybe if you were to remove the dust shield maybe you could put a vise on a floor jack and bring it up to level, put a socket over the head to give it room and get it moving out.
Old Jul 27, 2013 | 07:25 AM
Zychron's Avatar
Zychron
Something isn't right. Are you using 7/16-20 studs? 4 1/2 turns on a 7/16-20 stud is less than 1/4 inch thread engagement.
Old Jul 27, 2013 | 08:20 AM
Hammerhead Fred's Avatar
Hammerhead Fred
Even if you get the studs out, how will you get the longer studs in with the axle mounted on the carrier?
Old Jul 27, 2013 | 09:45 AM
starr69's Avatar
starr69
The reason for removal is that I'm going to use a 1/2" spacer. Upon replacement, I plan on drilling a hole in the plate. That should allow enough room to install the longer stud.
Old Jul 27, 2013 | 09:54 AM
wcsinx's Avatar
wcsinx
on all counts
Old Jul 27, 2013 | 12:17 PM
Hammerhead Fred
You might want to do a search and talk to others who've tried this.
Have you located longer studs that actually fit the hub?
Most require a larger diameter shank which will force you to drill out the hubs oversize.
Wheel/hub adapters would save you alot of time, frustration and driving risk.
....and you might try drilling out that stud then collapsing it with a hammer & chisel.
Old Jul 27, 2013 | 12:32 PM
my 76 ray's Avatar
my 76 ray
There's no need to cut the stud before using a BFH. Just knock the full length stud out.
Old Jul 27, 2013 | 04:25 PM
gcusmano74's Avatar
gcusmano74
Or drill it out, as a last resort.
The studs should be long enough to stick out PAST the nuts by 3 or 4 turns.
Old Jul 27, 2013 | 07:24 PM
starr69's Avatar
starr69
Hammerhead you hit it on the head. I heated the one stud that I cut off and knocked it out. Re-installed an OEM stud and Im going to buy a couple of hub centric adaptors. I had no idea what I was getting into. Thanks for everyones help. I'm positive I will need it again.
Old Jul 28, 2013 | 11:59 AM
BB2B's Avatar
BB2B
American Racing carries replacement lug nuts with extended shanks for use on custom wheels and wheels with spacers. I use them with Torque Thrust D wheels and did not need to use longer studs.
To Wheel Stud Question
