Strange coolant leak
Old Jul 27, 2013 | 07:38 PM
1978vett's Avatar
1978vett
Default Strange coolant leak
I noticed a few drops of coolant on the garage floor ,, it doesn't leak a drop when it is warmed up and running ,, just the first start of the day it leaks for maybe 20 seconds and stops.. i'm pretty sure it is coming from the plastic fitting that connects the 2 small hoses that go to the heater core.. Can someone tell me what the fitting is called ,I am going to replace it,, I drove it for 2 hours today and it hasn't leaked a drop..I am goint to try and atach a picture,, also there is a aluminum line ac I think that is wraped with something ,, I'm curious about that too.. Thanks alot for any help.,,Sorry ,,but I think the picture is upside down...
Old Jul 27, 2013 | 09:02 PM
TimAT's Avatar
TimAT
That plastic fitting looks to me like the water shutoff. The tape looking stuff is insulation tape. It's kind of a tar based tape with rocks in it. Keeps the cold in the A/C and the heat from boiling the liquid Freon back to vapor before the orifice tube.
Old Jul 27, 2013 | 09:30 PM
mds3013's Avatar
mds3013
Cork tape. As TimAT stated it is for insulation. Also check the hose connections at the heater core. The two hoses are the heater hoses and they go down to the heater core connections. As the coolant heats up everything expands and can seal off a small leak. It then can show up again when the coolant cools off. mike...
Old Jul 27, 2013 | 10:40 PM
1978vett's Avatar
1978vett
Thanks,, what does the water shut off do ?,, I have checked the connections at the heater core,, they are dry,, when it leaks it runs down the frame then drops off.. It seems to start right below the plastic fitting.. But only leaks for maybe 20 or so seconds when it is started cold
Old Jul 28, 2013 | 12:35 AM
TimAT's Avatar
TimAT
The water shut off is supposed to stop coolant flow thru the heater core anytime the mode selector is in any position other than HEAT or DEFROST. Key word is "supposed to".
As far as the drips, tighten the hose clamps and see if it stops. Cheap plastic valve could have a small crack or one of the hoses could have a bubble in between the liner and the outer covering that fills under pressure and then drains when the pressure goes back down. When it's hot, the pressure goes up- and goes up a little more when you shut the engine off.
Old Jul 28, 2013 | 09:33 AM
1978vett's Avatar
1978vett
Ok , thanks for the replies and info...
Old Jul 28, 2013 | 10:32 AM
1978vett's Avatar
1978vett
Couldn't I connect the 2 hoses together that connect to the fitting? I know that would bypass the heater core ..
Old Jul 28, 2013 | 10:43 AM
mds3013's Avatar
mds3013
Yes you can. You could also remove the hose fittings from the intake and water pump and plug them. Those fittings can be next to impossible to remove without damage however. mike...
Old Jul 28, 2013 | 12:12 PM
1978vett's Avatar
1978vett
It must be stuck in the closed position, The heater just blows out cool air,, doesn't seem to change when I put the control to heat or defrost...
To Strange coolant leak
