caliper issue..weird.
Old Jul 22, 2013 | 08:20 AM
4 speed's Avatar
4 speed
Default caliper issue..weird.
so I notice that my RR caliper doesn't appear to be working. rotor is pitted and still so what rusty, the other 3 are shiney fresh metal.
so I blead the RR, just a smidgen of air . so I pulled the pads and had the wife slowly push the pedal, I could see the pistons moving out toward the rotor.
there are no leaks that I can see.
why would this caliper not be braking like the others ??
Old Jul 22, 2013 | 10:07 AM
bashcraft's Avatar
bashcraft
How do you know it's not working?
Old Jul 22, 2013 | 10:25 AM
don hall's Avatar
don hall
See OP's post:
"rotor is pitted and still some what rusty, the other 3 are shiney fresh metal."
Old Jul 22, 2013 | 10:34 AM
bashcraft's Avatar
bashcraft
Originally Posted by seabright
See OP's post:
Hmm.. I read something completely different there.
Old Jul 22, 2013 | 11:24 AM
Tom454's Avatar
Tom454
One possibility... (there are others)
If you have the OEM style rubber hoses, unless the steel line is crimped, the rubber hose is collapsed on the inside blocking most (but not all) of the line pressure to that caliper.
Old Jul 22, 2013 | 05:02 PM
4 speed's Avatar
4 speed
got good pressure when we bled the brakes
Old Jul 23, 2013 | 09:41 AM
Tom454's Avatar
Tom454
Do you have rubber hoses, or SS covered teflon hoses?
Pressure or flow? (they're different) If you replace the RR caliper with a pressure gauge, you can read pressure, at the same time, no flow.
Where did you get the "pressure" ? At the M/C or at that caliper?
If the other rear calper is working good, there should be full line pressure at both rear hoses but the flow on the RR could be insufficient to move the caliper pistons enough to engage the rotor.
Here is what I would do...
Pull the caliper & hose.
If the hose is OEM design rubber, replace the hose.
Disassemble the caliper and determine it's design- OEM or aftermarket, stainless sleeved or rusty.
Based on what you find, install new seals, boots and the o-ring.
Reassemble it all & re-bleed the lines.
Old Jul 24, 2013 | 06:19 PM
4 speed's Avatar
4 speed
when we bled the brakes we got a good "squirt" of fluid out of the bleeder.
then I pulled the pads and had my wife slowly push the pedal to see if the pistons were moving and they were.
of course now I am having a time getting the pads back in, think its just to hot out today.
Old Jul 24, 2013 | 09:56 PM
hugie82's Avatar
hugie82
I've had strange brake bias before. It might sound a little bubba but I pushed back all the caliper pistons while they were mounted. I used wood shims for construction (installing doors and windows). Make sure the master cylinder doesn't overflow. The pistons don't need to be all the way pushed in just a little.
Then I pulled them all out. Starting with the RR,LR,FR,LR. You'll see the brake fluid level drop in the MC. Top it off and then slowly start pumping the brakes pedal. (Like barely creeping down about 1/2 way) not to the floor. The pedal will get rock hard and then you can start the car to use the power booster to work it some more.
It works by getting all the air out and pumping very slow keeps the proportioning valve /check ball centered.
Its worked every time
Old Jul 25, 2013 | 08:43 AM
4 speed's Avatar
4 speed
are you saying to pull all the brake pads, then shim each piston back with shims. then bleed the brakes.
Old Jul 25, 2013 | 10:10 AM
wombvette's Avatar
wombvette
This is in fact a weird problem if it is as described. You say the pistons move when you press the brake pedal. If that is the case, and the pads are not stuck, that thing is going to brake and the rotor will eventually be slick. However it is obvious to me that the clamping force is almost nill on that rotor. So something is causing the piston not to clamp. You need to go down that path to find what is wrong. Start at the MC make sure there is pressure. Go down the line to that caliper and look for kinks and any obstructions checking pressure as you go. Rubber lines are notorious for blockage, but usually that is an opposite symptom. Then to the caliper. Just some observations on what I see in the picture. The calipers are offshore replacements not GM. I would suspect them. The last person to install them didnt know or care about the correct hard line replacement position. That thing is over top and hanging out in a dangerous place. I would look at it for kinks that would stop flow.
Have someone press the brake and try to turn that wheel and compare the clamping force to the others.
Old Jul 25, 2013 | 10:21 AM
redwhitekat's Avatar
redwhitekat
I've had a weird problem to after replacing the pads all around the car pulled to the right big time to the point my right tire would lock up. Replaced both front calipers and it's a lot better but still pulls a bit
I bleed the brakes all around
U might just need to replace your calipers and bleed brakes
Old Jul 25, 2013 | 11:31 AM
hugie82's Avatar
hugie82
No, leave the pads in and place the wood shims between the rotor and pad. You might need a screw driver to push the pad back to get the shim in.
You can crack the bleeders just to let a little air out but I assume you've done that a bunch of times already.
The idea is to forces all the fluid and air pockets up through the master cylinder. Also it pushes the check ***** back in the proportioning valve.
The proportion valve needs to stay reset. This is way you have to push the brake pedal slowly after removing the shims and don't bring it all the way to the floor. It might take 10 minutes of pumping slowly but when you get the pedal back, it will be firm
Good luck!
Old Jul 25, 2013 | 12:19 PM
noonie's Avatar
noonie
Just put the pads back in and bleed that caliper again.
If you got "a good squirt" from that bleeder, then nothing should be obstructed.
The hose on that side may be deteriorated enough to expand, but that should lose pressure on both rear calipers, same with air.
Just sounds like the pistons are seizing in the bores of that caliper.
Don't be afraid to stand on the pedal as hard as you can to test and check wheel for rotation or leaking.
BTW, there are no check valves anywhere, if you have lots of fluid bleeding, you're golden.
Old Jul 26, 2013 | 05:28 PM
4 speed's Avatar
4 speed
so how do you get the pads back in, I can't get the pistons held back to slide the pads in.
do I have to pull the caliper to put the pads in ???
Old Jul 26, 2013 | 05:49 PM
'75's Avatar
'75
Use a wide putty knife to hold the pistons back while you put slide the pad in.
Old Jul 26, 2013 | 09:38 PM
4 speed's Avatar
4 speed
I just pulled the caliper and they dropped in and I pushed them back , only took about 5 min.
To caliper issue..weird.
