Your opinion on this engine setup please.
So I have super comp hooker side pipes with glasspack mufflers and would install the trick flow kit TFS-K314-350-400 somewhere next year but now I would already start with the manifold and carb to go with this head/cam kit.
http://www.trickflow.com/partdetail....N=400098++150+
I've asked the shop what manifold and carb would be good for this setup and car.
He suggested the edelbrock 2101 with a holley 0-80555c carb.
but I read that the air-gap is beter but I'm afraid I will have hood clearance issues, (maybe with a moroso drop base filter ?)
If I would go with an air-gap performer or rpm should I go with a Holley 4150 ?
Or what about the EPR performer ?
I know there are some experienced people on here that might give me an opinion on what would be best for me as I am kinda lost in the choices....
put the money towards heads and a cam, or a crate motor.
or go with the 2101 (just for the weight savings). otherwise you'll be spending money on a hood also
But I need to get an intake and carb for that setup, and that is what I am asking here as I have no idea what would be best with thet kit and what would fit under my stock hood ( maybe with a drop base moroso filter)
I would buy the intake & carb now and somewhat later the heads/cam kit.
Also, there are better intake manifolds than the stock L-48 unit; but you won't improve anything by swapping out the Q-Jet carb....except maybe get a big drop in fuel mileage and poorer idle and transition behavior. But, if you install a hi-rise manifold, you may need to modify your hood.
Prior to ANY engine parts swaps, you may want to dial-in what you now have for a nearly-FREE 30+ HP improvement: re-curve your distributor for 'performance', do a tune-up on the ignition system, and adjust (or rebuild, if it needs it) your carb/choke. You also need to verify that your throttle cable/linkage system is actually opening your secondary throttle plate completely when your accel pedal is pushed to the floor (not checked with hand-actuation of carb linkage).
Until you make those 'simple' changes to your existing engine, the other things you are considering are a total waste of time and money.
What intake / carb would work best with the trick flow top end power kit ?
TFS-K314-350-400
Taking in consideration that it has to fit under a stock 75 hood. I don't mind using a drop base filter.
