Help!
Old Jul 24, 2013 | 12:04 PM
Paddyo's Avatar
Paddyo
7th Gear
Default Help!
I have a 1969 L36 427. It has a rear main seal leak. Do I need to pull the. Engine to replace? Any advice would greatly be appreciated!
Old Jul 24, 2013 | 12:18 PM
MelWff's Avatar
MelWff
The pan drops without having to remove or raise the engine.
Old Jul 24, 2013 | 12:22 PM
Paddyo's Avatar
Paddyo
7th Gear
Default Thanks
Thanks!
Old Jul 24, 2013 | 12:25 PM
MelWff's Avatar
MelWff
You have to drop the steeering linkage to get clearance
Old Jul 24, 2013 | 02:49 PM
my 76 ray's Avatar
my 76 ray
If you unbolt the idler arm from the frame you will have enough clearance to remove the pan.
Old Jul 24, 2013 | 03:47 PM
7T1vette's Avatar
7T1vette
You need to access info on the internet as to the procedure for changing the rear seal on a Chevy V8 engine.
To Help!
