Question about prepping for primrer
Old Jul 24, 2013 | 05:35 PM
Marine93's Avatar
Marine93
Default Question about prepping for primrer
I have spent a LONG time scraping the paint off my frame off resto. I was very careful NOT to gouge the hell out of it in the process. However, the inevitable light gouge here and there is what I ended up with, nothing real deep but enough to where it needs to be addressed. Is this a time for regular bondo? or is there something better? I've seen the shows on TV where they put on a huge glop of some goo that looks to have the consistancy of mayo, it's really thin and they spread it on with a big squeegy looking type thing..... what is that? is that like a final glazing or something? thanks for any help!
Old Jul 24, 2013 | 06:01 PM
Alan 71's Avatar
Alan 71
Hi M93,
I believe it's a good idea to fill each gouge with a dab of fiberglass resin. You need to carefully work the resin into each gouge so you're certain there's NOT a tiny air bubble left under the resin.
I think the less bondo type filler that's used on fiberglass bodies the better the paint job looks and the longer it lasts.
Regards,
Alan
Old Jul 24, 2013 | 09:04 PM
BigAl5611's Avatar
BigAl5611
Alot depends on weither it's fiberglass or smc. For fiberglass use resin like Alan said, smc you can use Vette Bond.
Old Jul 24, 2013 | 10:21 PM
Marine93's Avatar
Marine93
It's a 76' so I believe it's SMC.... correct? I thought anything after 74' was SMC
Old Jul 25, 2013 | 08:43 AM
fishslayer143's Avatar
fishslayer143
if your scratches are very minor, prime the area, then use Spot/Glazing putty to fill in, sand and reprime..do not use on just bare panel .. available anywhere Auto paint is sold
Old Jul 25, 2013 | 08:54 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by BigAl5611
Alot depends on weither it's fiberglass or smc...
Er...uh...SMC is fiberglass, just a different compound than the old polyester.
Old Jul 25, 2013 | 08:55 AM
jnb5101's Avatar
jnb5101
surprisingly, two coats of epoxy primer will fill all of the 'slight' gouges. and if you're spraying a coat of filler on top of the primer, block sand it, then shoot another coat of epoxy, then glaze any (probably won't need it) remaining defects. in any case, you want epoxy as your layer under the color. spi epoxy is great because it has a 7 day recoat window.
Old Jul 25, 2013 | 11:14 AM
BigAl5611's Avatar
BigAl5611
Yes...correct, much different then polyester resin/galss.
Old Jul 25, 2013 | 11:25 AM
BigAl5611's Avatar
BigAl5611
Yes it's SMC glass. You can use a high build primer like the Mar-Hyde Urethane 2K Primer. It's a 2 part primer that is very easy to use and sand. Use the Buff or Vanilla color if your going a lighter color as it is the easiest to sand. If your going dark get the black, it works and sands well, just a little harder on the sand paper.
Old Jul 25, 2013 | 12:41 PM
Marine93's Avatar
Marine93
Thanks for all the help guys, I'm doing this for my son in the Marine Corps, he's getting ready for second deployment in afghanistan and I'd like to have it done by the time he gets back (8 months) I have done boats before but never something like this. I'm not going to do the color coat but would like to have it all ready to go for the shop that is shooting the color. I'm just a bit confused as to the order of things... I have read so much and everyone says something different. After razoring the paint, there is still a coat of what looks like primer on all the body and doors, t-tops and hood, the front clip will be all new and not purchased yet. It's a grey primer, please tell me I DON"T have to take that down too! the paint job that was there was thick, gloppy and runny.... worst I've seen. I can spray, I have the equipment and fancy myself more than capable, I just need a good solid plan with the right products thats going to be the easiest to work with and yield the best results. Just to let you know he wants a deep metallic red for the final color. I was told to be careful what kind of primer you use because the paint guys paint may not work... my head is spinning!!! information overload I tell ya!!
Old Jul 25, 2013 | 11:17 PM
20mercury's Avatar
20mercury
Default no paint expert at all, but IMHO...
no paint expert at all, but I read a lot of posts here on paint and like you it appears there are lots of ways to do this.
IMHO, since you are going to get a shop to do the final paint, one good piece of advice I saw here was to go talk to the paint shop ahead of time before you get much further and see what they want. I do not know how much the paint shop will guarantee their work, but I am betting getting the paint shop advice beforehand is the way to go.
Hope this helps and good luck with your project.
Old Jul 26, 2013 | 12:59 AM
Marine93's Avatar
Marine93
Indeed!!! I already had that as a plan 20m... I know that some shops will refuse the job unless they do it all, well.... I don't have that kind of money, nor does my son. I'll tell you this, with everything that has been done, bought and paid for.... like new wiring harnesses, new everything, so far we are into it about $14,000.00.... I have done all the work but the powder coating and the rebuilds of the tranny and the rear end.... this will be a complete custom interior from the ground up.... I'm a journeymen carpenter and will be building the new console as well as the dash for the gauge cluster and such.... it's been a ton of fun and a hell of a lot of work but I know I'm preaching to the choir here... you guys are awesome and I truly appreciate the help and advise!!!
To Question about prepping for primrer
