HELP battery drain
Old Jul 26, 2013 | 04:41 PM
zambo75's Avatar
zambo75
Default HELP battery drain
1975 c3 corvette auto
OK, I have removed the neg battery terminal connected a amp meter from post to terminal was drawing 11.5 amps removed fuse one by one and still have a draw ,key in off position, no fuses left in box!
any help would be great ????
thanks steve
Old Jul 26, 2013 | 05:08 PM
'75's Avatar
'75
Disconnect the alternator and see if it drops the amperage.
Old Jul 26, 2013 | 05:37 PM
zambo75's Avatar
zambo75
still have it
Old Jul 26, 2013 | 08:43 PM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Old Jul 26, 2013 | 09:19 PM
'75's Avatar
'75
Have you made sure the alarm key is off? Removed the circuit breaker for the windows? 11.5 amps is a good sized draw. Does it change with the doors closed?
Old Jul 26, 2013 | 10:28 PM
SIXFOOTER's Avatar
SIXFOOTER
Wow, that is a big draw. You obviously have something turned on that shouldn't be. Alarm is a good place to start. Aftermarket alarm, stereo, Amp?
Old Jul 27, 2013 | 01:22 PM
zambo75's Avatar
zambo75
Default help
The previous owner removed the alarm, tided the two pink together in the back ,and the front under the hood still have the wires unhooked ,all the parts are gone , key cylinder, horn from back. have a wiring diagram from lectric wiring .
Old Jul 27, 2013 | 02:40 PM
dochorsepower's Avatar
dochorsepower
Check the wire harness clamped to the back of the alternator. I also have a '75 and the metal clamp wore thru the wrap and the wire insulation. There is another common problem with this vintage, the wire bundle can wear thru where it passes thru the cowl.
Good luck.
To HELP battery drain
