AC brackets and headers
Old Jul 31, 2013 | 08:02 PM
FatCat's Avatar
FatCat
Default AC brackets and headers
Anyone have a picture of how to modify AC brackets on a 1978 with headers?
Thanks!
Old Jul 31, 2013 | 10:52 PM
KapsSA's Avatar
KapsSA
Active Streak: 90 Days
The only thing you need to do on the 78 is make up a spacer(or stack of washers)the thickness of the original exhaust manifold minus the thickness of the header flange to support the side of the main bracket.
Everything else will bolt right up.
Old Jul 31, 2013 | 11:53 PM
FatCat's Avatar
FatCat
So that is bolted to the header flange if I am seeing correctly?
Old Jul 31, 2013 | 11:59 PM
FatCat's Avatar
FatCat
Old Aug 1, 2013 | 09:23 AM
KapsSA's Avatar
KapsSA
Yeah, you use the same long bolt with the extended stud that was originally in that forward location with the original exhaust manifold.
Old Aug 1, 2013 | 09:50 AM
tyancey00's Avatar
tyancey00
that is correct on my 80 as well. it has threads to lock down the header and then threads on the other end to lock down the compressor. Great fun to work on these cars. They smoked a lot of pot coming up with these workarounds...
Old Aug 1, 2013 | 01:09 PM
FatCat's Avatar
FatCat
Thanks! I will have to figure out the bot size since this is all replacing from PO.
Old Aug 1, 2013 | 01:26 PM
FatCat's Avatar
FatCat
Thanks! I will have to figure out the bolt size since this is all replacing from PO.
Old Aug 1, 2013 | 01:56 PM
tyancey00's Avatar
tyancey00
i threads into the Head just like the headder bolts. It will be the same thread they have... i don't know what size that is but if you match it to one of them you will be fine. The long part can be any size you want ... should be plenty of car shows this weekend where you could go look at one in person and see what we are talking about...
Old Aug 1, 2013 | 04:34 PM
KapsSA's Avatar
KapsSA
You could always use a length of 3/8-16 threaded rod.
Screw the rod in in place of the header bolt, slip your spacer over that and lock it down with a nut. Install the bracket and lock that down with another nut.
Old Aug 1, 2013 | 08:06 PM
FatCat's Avatar
FatCat
Thanks guys! I will give it a try this weekend.
To AC brackets and headers
