Dumb Question about crate engines
Old Jul 31, 2013 | 10:56 PM
ex9850's Avatar
ex9850
Default Dumb Question about crate engines
Can you get a new crate engine that uses v-belts rather than a serpentine belt?
Old Jul 31, 2013 | 11:06 PM
bluedawg's Avatar
bluedawg
I'm sure you can, unless you buy a crate engine with the belt system already installed, you'd either use your existing system or buy another system if your choice.
Old Jul 31, 2013 | 11:28 PM
ex9850's Avatar
ex9850
So does my old crank pulley (the one on the old motor) bolt to the new engine's crank? I don't know if the pulley is part of the rotating assembly or bolted on later.
Old Aug 1, 2013 | 01:04 AM
bluedawg's Avatar
bluedawg
Mine bolted to my new harmonic balancer that I bought for my 400. I might be wrong but it should be spec for all or at least most sbc's to have the same bolt pattern on the balancer. I'm sure that there might be some exceptions, but I'd think you'd be alright reusing your crank, water pump, power steering and alternator pulleys on a crate engine. I don't believe they'd work on lt or ls engines.
Old Aug 1, 2013 | 04:31 AM
ex9850's Avatar
ex9850
Thanks BlueDawg. I checked elsewhere and got the same answer.
Old Aug 1, 2013 | 11:34 AM
bluedawg's Avatar
bluedawg
Your welcome.
To Dumb Question about crate engines
