Can you read these plugs???
And here's a closeup of the new 44 and old 45 from #2 cylinder:
I have set the initial and mechanical set to under 29 until I get this figured out. While I'm writing this, it occurred to me that the vacuum advance was connected and at one time I had it on my list to verify the actual advance since I didn't check recently it and it's not so easy to replicate accurately in the garage.
It's really hard to hear the engine with the Flowmasters and the loud timing gearset. However, while cruising I hear was appears to be a constants rattle and it appears to stop when pressing on the throttle.
At the moment, it kind of looks like I may have solved the issue??
Anyone have a recommendation for a proper vacuum canister on a GM HEI distributor?
Thoughts?
What carburetor are you using and what jetting, may be lean.
Have Lars paper and his list of canisters (not terribly clear to this cluttered mind). As for vacuum advance testing, this 350 has a fairly aggressive cam and idles at 950+- with about 8-9hg, but at 2500 is getting 22hg.
Not sure, but I think the difference between vacuum and no vacuum at idle is not indicative of what is happening at 2500 while cruising.
The carb is a 650 Holly single pumper with vacuum secondaries. I believe the secondaries are opening properly, but that has been an issue previously. Don't think they are open while cruising though and if they were, wouldn't that just lessen the issue of a lean mixture.
The jets are stock and I believe the are 65's. Another thing about this setup is that it burns a lot of fuel as SBC's go. Like maybe less than 9 mpg.
My next thought is to to disconnect the vacuum advance an see what happens to the rattle/noise. I did do that last time out to see if it made any difference in the plug color - it didn't, but I neglected to associate the issue with that noise so I will do that as soon as I get another set of plugs.
Anyone want to venture a guess as to which plugs I should use next?
If your vehicle was not calibrated for a fuel blended with ethanol the following adjustments can be done to restore the expected mileage and performance prior to the change in the fuel type. NGK Spark Plugs Canada Limited recommends to install a spark plug one heat rating cooler than OE to dissipate the increase in cylinder temperature as well as adjusting the spark plug gap setting to 0.010” smaller then the vehicle’s factory setting (Note: do not reduce gap to less than 0.035”.
Did you just pull the plugs one day after cruising around? To get a more accurate read, you are supposed to warm-up the car to normal temps and go though the gears hard and then immediately shut-off the engine and coast over to the side of the road and pull the plugs to take a reading. You don't read the porcelain to tell the mixture. You're supposed to look at the color of the ground strap and the end of the plug that the strap is welded to (base ring).
I'm sure there's a million plug reading posts, here's one at http://members.uia.net/pkelley2/sparkplugreading.html.
Not sure I understand your post completely. You are running initial, mechanical advance and vacuum equaling 29 degrees? Even if only initial and mechanical advance, that is way low (retarded) and would cause increased engine temps and who knows what that is doing to affect reading the plugs. You need to get your timing up first, before fine tuning anything with the plugs.
http://www.ngkplugpro.ca/content/con...ol_fuel_en.pdf
Lots of thoughts on timing - originally retarded the timing a bit just to make sure there would be no detonation while I was trying to reduce the operating temperature. Had/have every intention of resetting it to 36+-. I just need to get my head around the proper steps/changes. I'm having some difficulty with slightly retarding the timing will causing all of the symptoms I'm seeing. In particular, the detonation.
In looking at the page/above link (been to that page before), there is every indication that the color of the porcelain is not absolute and really only determines if there is any detonation going on. I believe there is as there are some fused black spots on the nearly white porcelain.
The base ring helps determines how well the jetting is set - these plugs tell me the jetting is a little on the rich side - contrary to what looks it looks like from the photos. All of that seems to coincide with the tail pipes - dark with soot.
This is part of my confusion, but the other part is that the R45 plugs all looked like the lower two (45's) and the 44's went white.
Then we get into reading the ground strap, which is the reason I changed to the 44's in the first place. The 45's showed the color change at the bend and the 44's now show the color change near or at the base ring - just the opposite of what I had hoped to accopmlish.
Everything I have read is that a properly set up 650 will produce 800HP??? But your point has been in the back of my mind for some time now.
I think the first thing is to get a clean set of plugs (44's are colder than 45's - yes?) so probably another set of 44's.
Need to verify the effects of the current vacuum advance canister at cruising RPM's and obtain a new one that more closely creates the proper advance at 2500+- RPM.
Need to set the initial timing about 13+ degrees and verify that the mechanical advance brings it all in at 33+/2700 RPM
Then I need to verify that the ground strap on the new plugs has a color change at the proper location near the bend but still on the flat part. Also verify that there is no indication of preignitiion and that the seemingly corresponding rattle at highway speeds has been eliminated.
I'm not sure that I need to change the jets since all the colors (base ring and tail pipe) indicate that it's a bit on the rich side already?? Ran across this chart when looking through this part of the project.
http://walkerproducts.com/_pdf/holleymeteringjets.pdf
My guess is that most of the problem lies in the vacuum canister - I will zero in on that.
Thoughts?
Did pull the plugs upon returning from a 50+ mile round trip inland to warmer climes, primarily to see if I had made any progress on the high operating temps while running at highway speeds in ambient temps of 80+ degrees. There was quite an improvement.
Good thoughts - no power steering though. Will attempt to make that happen.
What I wrote about not turning the key all the way counter-clockwise has nothing to do with power steering. I'm trying to warn you about locking the steering wheel when you are going 80-100 mph. You don't want to bring the key all the way back toward you as if you were going to remove them, The wheel will be mechanically locked in place if you do. You need to think about a place to do this where there isn't any traffic and you have a safe place to coast the car over to pull the plugs.
The rule of thumb is get the timing right first, then the mixture. The plugs come in third. The timing is the most critical setting on the engine when it comes to making power and having it run right. Some of these engines run at 36-38, some even lower. The figure you see most often is 36. When you say you are running under 29 degrees and you don't know if the vacuum advance was hooked up or not, you're leaving quite a bit of room for retarded timing. My vacuum advance contributes 5 degrees at idle. If yours is similar, you could actually have as little as "under 24" when it's all in. You should read up and get the timing procedure down in your mind and go after it first and find out where you are. You definitely want the vacuum advance disconnected when you time the engine.
A formula for generally sizing the carb is displacement x max rpm x volumetric efficiency/3456 = cfm. I know nothing about your engine but being optimistic and saying VE = .92, the carb size is 606 cfm. 650cfm will not make 800HP. I'm sure there are people running 750s on an engine similar to yours. No hard and fast rule.
Hope to put it on a dyno after this all gets sorted out. Found out that many companies that have a dyno will run your car, but will not tune it.
Putting the plugs back in only to take them out again was not something I wanted to do - headers and all. So I pulled the canister and thought you guys might want to know what I stumbled on.
The existing canister had no identifying references stamped on so I devised a bench test that told me what should be happening at cruising/idle.
First I determined that the point of the connection to the advance arm on the dist. is on a 1.5" radius (3" diam.) Then I measured the amount of movement which turned out to be 1/4" at full vacuum of 12-13hg. 1/4" calcs to be dist. 9.55* or 19.1* crank. So cruising I should have been getting 19.1 on top of mechanical. Can't say what part this may have played in the point at hand, but this is just for the record.
The start of movement was at 7hg so at idle (with 8.5hg) it was not fully engaged and this causes (according to Lars and others) the vacuum to change the RPM and to then change the vacuum and all over again - something that this engine has done from the beginning.
I happened to have another relatively new HEI dist with a vacuum advance so I pulled that and tested it to see if it might be useful. It turned out to have a good starting point at 5hg, but the travel produced almost 27 crank degrees of advance.
Since the starting poiint was better for this engine, I modified it by restrict the travel with a small plate and some epoxy. The result was fully advanced by 7hg and produced 15.1* advance at the crank.
I'll let you know how this works out after I set the timing once again.
BTW, I did not find this little tip on the internet - it's just something I happened to dream up. I'm sure it's been done before, but I never encountered it.
The black marks were much the same as those on my R44TS's except that on the 44's, the marks were now baked on and couldn't be cleaned. That could have lead me to think that I had detonation going on???
Decided not to get them and went to O'reilly's and their R43TS's weren't much better but was at least a matched set of boxes. Bought them and went out to the car and decided to open the boxes only to find that two of them had chips in the porcelain around the electrodes - not small chips either.
Went back inside and the sales guy told me AC Delco QC was not very good any more. Sold me a set of Accel 0567 (was supposed to be the same heat range but turns out I should have gotten 0574's), and off I went - 33 miles home.
Get home and open the plugs only to find the end of the ground strap was flared to a point on the 3 outer sides. Don't need that in my engine. Also, the electrode on half of them was not in the center and didn't line up with the strap.
So, heading back to town to find another set, but looking for a recommendation from you guys??? How about Autolite 24's - anyone use those?
This shouldn't be that difficult???
I'm also of the opinion that NGK makes darn good plugs. The next set I install will be some NGK Irridium plugs, in hopes that their extended lifespan (over 100K miles in electronic ignition cars) will eliminate the need for me EVER to have to change plugs again. And, if I find that I need to go to an electronic ignition for them to perform correctly, I'll stick a Pertronix module and a compatible coil in the ignition system.
