Speedometer fluctuation
Old Aug 1, 2013 | 11:54 AM
archer417's Avatar
archer417
Default Speedometer fluctuation
I was told that I could squirt some graphite onto the end of the cable but I'm not even sure which end to try that. The needle fluctuates badly. For example when on the hiway it bouces back and forth between 40-80mph.
Would some graphite help that or do I need to replace parts?
I apologize for basic type questions but I haven't been under the hood of a vette since about 1987.
Old Aug 1, 2013 | 12:07 PM
76stingracer's Avatar
76stingracer
It could be the cable, or the plastic gear in the transmission or the speedo not working correctly. Start with pulling the cable out of the trans and try to spin the cable by hand to check the cable. If it spins freely then the issue is the gear or the speedo.
Old Aug 1, 2013 | 12:44 PM
DC3's Avatar
DC3
Trace the cable to make sure its not kinked and in a bind somewhere. Lube could help but you have to make sure to use the right stuff. Graphite or another dry lube would probably work but I wouldn't use anything that doesn't specify its for speedometer cables. Definitely don't use any kind of grease. It can work its way into the speedometer head and cause you problems.
If you take your speedometer cable out, you should be able to pull the inner cable out of the outer sleeve, lube it properly, reinsert and then test it with a drill to see if its smooth. You might need a new cable (or two). Some of our Vettes use a one piece cable. Others use a 2 piece. If you have cruise control, you have two different cables. I can't remember the differences in year models but one of the vendors could help. You might even find cables at a local Chevy dealer.
DC
Old Nov 20, 2013 | 02:18 PM
archer417's Avatar
archer417
I lubed both the upper and the lower cable but neither helped the issue. Also ran the cable with the drill and the needle remained steady. I completely replaced the speedometer cable and bypassed the cruise control. Now the speedometer needle is just as smooth as silk! I didn't need cruise anyway!
To Speedometer fluctuation
