Old Sending Unit has a Condencer?
Old Aug 3, 2013 | 07:45 PM
Charliebates's Avatar
Charliebates
Default Old Sending Unit has a Condencer?
I'm just about ready for my mechanical inspection and then I can register, get plates & drive the car.
I'm replacing the original sending unit on my 1982 and it has what appears to be a condenser mounted right above the sending unit pivot arm.
It's welded on the support arm tube so it is permanent .
The power to the fuel pump runs into one end of this condenser and out the other end and then to the fuel pump.
I have a the new replacement sending unit that comes with out this condenser.
Do I proceed with the install? Or do I have the wrong part?
Thx John
Old Aug 4, 2013 | 12:49 AM
Charliebates
Bump
Old Aug 4, 2013 | 03:59 PM
centralcalvette's Avatar
centralcalvette
So I'm guessing we're talking about the fuel level sensor, right? Well, we'll go with that. If your new sender comes with out a condenser, one could only assume it's no longer required. A "add on" item on a fuel level sender was probably added by the engineer to eliminate a design flaw. I would use with the new one as-is.
Old Aug 6, 2013 | 11:13 PM
Charliebates
Darn-it. I missed your reply.
I decided the fuel pump worked fine with the old style condenser so I installed it on the new one. I now have a functioning fuel gage.
Thx for the advice.
Old Aug 7, 2013 | 04:14 AM
7T1vette's Avatar
7T1vette
I don't know what the electrical circuit looks like for that system, but the condenser (capacitor) might be for dampening the movements on the fuel gauge needle.
Old Aug 7, 2013 | 11:00 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Charliebates
...I decided the fuel pump worked fine with the old style condenser so I installed it on the new one. I now have a functioning fuel gage...
That works.
To Old Sending Unit has a Condencer?
