No More Carb Issues...BUT...
Old Aug 6, 2013 | 06:26 AM
American Raven's Avatar
American Raven
C3 Corvette Enthusiast
Originally Posted by 1HotZR-1
What makes an Edelbrock carb questionable at best? there are thousands of them installed on cars and hundreds on this forum alone.
I'm running an Edelbrock 750 cfm (vacuum secondary) on my ZZ4 engine and it works great. I could never get the car to pass emissions with the Holley that came with the engine.
HOWEVER, I have read about some tuning nightmares about both Holley and Edelbrock carbs on the Mustang and Mopar forums.
Good luck in fixing your problem.
P.S. - Another forum I'm a member of had this thread about Holley vs Edelbrock on ZZ4's. Eddy's are great carbs (just as Holleys) - both have their idiosyncrasies and both have to be tuned correctly. They're hard to find these days but try to find a mechanic who understands carbs and have him jet and adjust it properly. Believe me, it's worth the money.
http://67-72chevytrucks.com/vboard/s...d.php?t=561424
Old Aug 6, 2013 | 07:56 AM
augiedoggy's Avatar
augiedoggy
What makes an Edelbrock carb questionable at best? there are thousands of them installed on cars and hundreds on this forum alone. The car had a Holley 750 DP originally. It made the car run like crap. I changed to the Edelbrock because it was a 600 cfm. The same cfm that the car came with. Plus I gained the manifold port back. The previous owner installed a bolt in it then installed the Holley, and "T'd" all the vacuum off it. Funny thing is, this all started just to get the lights to work properly. The PO said the lights quite after the carb install. Well, he lied. And about other things as well. I will try and block off all the vacuum and see what happens. I tested everything before i installed them, and the only thing that created a vacuum leak was the booster, which I suspected needed changed. Also, I will change the timing vacuum assist to the driver side port and see how that works. I also bought some Sea Foam, and a new distributor as well. After that it is either valves, wires, or timing? Thanks everyone. I will let you know what i find.
Original qjet was a 750.... but otherwise your right the edelbrock its the most commonly used Carb...not the best but certainly not junk...they are one of the simplest designs and easiest to setup and maintain.... unfortunately many people stick to what they know and put down everything else....same reason so many remove the qjets as few understand them correctly.
I had a similar popping issue on my 74 which I found was caused by the heat controlled flap in the passenger side exhaust manifold being messed up and mispositioned and causing exhaust blockage on that side.. other possibilities is a leak in intake/Carb seal or exhaust or even a plugged cat if you have one....you can hit it with a temp gun to see if its overheating which they do when the are plugged....
Old Aug 6, 2013 | 08:56 AM
Yeller81USNRet's Avatar
Yeller81USNRet
I have a Edelbrock 1406 on my 81 and it works great also have a 1103 cam in it and love the sound. Have no idea what the horsepower gain was if any but I was after the lopey cam sound not especially HP. Isn't this a wonderful country where we can choose the things we want right or wrong.
Old Aug 6, 2013 | 09:55 AM
commander_47's Avatar
commander_47
Chances of this issue being with the Edelbrock are remote.
"popping" can be caused by so many issues that you really need to tackle it in a systematic manner.
I always try to start with the simplest first and work my way up.
1. Vacuum leaks. A very elusive culprit, but common on the C3. Block off everything, then connect them one by one and check for pops.
2. Intake leak. Spray a little marvel mystery oil around the manifold and carb. Look for a leak.
3. Ignition. timing, plugs, wires. Try and see if the pop is isolated to one cylinder. It probably is.
4. Adjust valves if everything above seems ok.
Old Aug 6, 2013 | 10:03 AM
cv67's Avatar
cv67
St. Jude Donor '05
Bet your carb issue is an ignition issue
Eddy carbs seem calibrated to a stock setup usually a touch lean.
They are not bad just like any carb most may need a little tweaking out of the box to work best for your app.
Old Aug 6, 2013 | 08:25 PM
Jim78SA's Avatar
Jim78SA
UPDATE!! First and foremost thank you all who have suggested possible solutions. I disconnected the vacuum advance and reconnected it on the driver's side port. I am pleased to announce the popping is gone. But, now it is in the yellow as far as vacuum goes and my eyes are burning from the gas smell. Is it possible I need to advance my initial timing now? I am pretty certain I do not have a vacuum leak around the carb area. I sprayed carb cleaner around the base and heard no RPM change. I buddy that helped me time the car said he set it between 6*- 8*.
Old Aug 6, 2013 | 08:26 PM
Jim78SA's Avatar
Jim78SA
Sorry about my grammar towards the end.
Old Aug 6, 2013 | 09:49 PM
694speed350's Avatar
694speed350
Originally Posted by 7T1vette
It likely won't. But the Edelbrock carb is the 'weak link' in your induction system. Quality 'out of the box' is questionable, at best.
Old Aug 6, 2013 | 11:04 PM
my 76 ray's Avatar
my 76 ray
Now I'm confused. Your original post said it was popping at all RPM's. Moving the vacuum advance to the driver's side would change it from ported vacuum to manifold vacuum. The only difference that should make is at idle. Once you open the throttle above idle there should be no difference based on which port you use unless you failed to plug the port on the passenger side. I didn't see whether the popping was at the carb or through the exhaust.
Old Aug 6, 2013 | 11:36 PM
Jim78SA's Avatar
Jim78SA
Was popping at all RPMs. Don't know what to say, but it isn't popping since I reconnected the vac to the driver side. My idle RPM went down when I did. It raised on the passenger side. I think it just solidifies I have an ignition problem. But, what problem? Timing off? Which I suspect is the culprit because it is an aftermarket intake. Let me just say, the car is running 10 times better than it was with the 750 Holley. Not saying Holley is crap or Edelbrock is better. What I am saying is, the Holley had issues, such as vacuum leaks. The car was also not firing on all cylinders, now is do to new plugs. I just want this thing to run decently until I can save up for my new crate engine.
Old Aug 6, 2013 | 11:38 PM
bluedawg's Avatar
bluedawg
I'd figure 12* but you've been elusive as far as the cam specs.
Old Aug 7, 2013 | 04:26 AM
7T1vette's Avatar
7T1vette
Do you have the 'correct' baseplate gasket installed under the carb. That gasket has holes in specific spots to direct manifold vacuum where it should go for THAT carb. Or, if not correct, it could bleed off manifold vacuum so that carb ports might not work properly. See if you can research a photo of the correct gasket for that carb and verify the one you got/used is right.
Old Aug 7, 2013 | 04:45 AM
  #33
RU7376vettes's Avatar
RU7376vettes
Before you go make hardware changes make certain you have the car properly timed and your distributor is working properly. First check to make certain your mechanical advance is freely working. I have seen broken springs and old grease gum them up which causes issues. Then get someone with a dial back timing light and knows what they are doing to time the car. The best way I have found is to disconnect and plug the vacuum advance hose and then set the timing so that you have around 34-36 degrees of advance when the mechanical advance is fully in which should be between 2000-3000 rpm depending on your distributor. That means that if your distributor mechanical advance is 20 degrees that your base distributor setting would be 14-16 degrees. Once this is set then reconnect your vacuum advance.
Unk
Old Aug 7, 2013 | 04:58 AM
  #34
RU7376vettes
I forgot to add that if you are having fuel burning your eyes, it is running rich and you need to adjust your carb. In an earlier post you stated that you had the idle screws about 2 1/2 turns out. The factory tells you to start with 1 1/2 turns. Then turn them in until it starts to stumble and then back them out to get maximum RPM and then reset idle speed. They have a good video on their website to show you how to do it. You should fist get timing set, then adjust your carb.
Unk
Old Aug 7, 2013 | 08:20 PM
  #35
Jim78SA's Avatar
Jim78SA
UPDATE...again: IT IS RUNNING GREAT! I never claimed to be the sharpest peanut in the turd. Yesterday, when I started it, it was running rich and burning my eyes. It also ran a bit rough. I thought is was a timing issue, or some other ignition issue. Well, I guess I was right...sort of. I went out to mess with it after work and noticed...DOH!, I forgot to connect the driver side spark plug wires. Yes, all of them. Reconnected them and VOILA! Running great and pulling 16" of steady vacuum. I plugged the brake booster back in and the vacuum went down, but I know I need a new one. Again, thanks for all the help. The manifold vacuum connection seemed to do it.
Old Aug 9, 2013 | 02:45 PM
  #36
Jim78SA's Avatar
Jim78SA
I can't believe no one thought this was funny. Geesh! Tough crowd.
Old Aug 9, 2013 | 03:22 PM
  #37
commander_47
I believe it's more a case of "those who live in glass houses shouldn't throw stones".
Anyone who has been working on these old beasts has done more than a few bonehead things.
I'm glad for you that was all it was.
Old Aug 9, 2013 | 03:29 PM
  #38
jackwabbit703's Avatar
jackwabbit703
I did not find it funny at all. I did some DUMB stuff while working on my vette also. I was just having "reflecting" moments of my mistakes as I was reading your post.
Old Aug 10, 2013 | 12:05 AM
  #39
Jim78SA's Avatar
Jim78SA
At least I am not the only one then. I was so thankful to be able to drive it (Somewhat). My wife was involved in a fender bender last night. Of all people, it was my boss, the Maintenance Chief Master Sergeant of my squadron. She was very empathetic though. So now at least I have the Vette to drive while the car is getting fixed.
