Steering Link spring loaded ball joint
Old 08-04-2013, 10:14 PM
Gearslingr
6th Gear
Gearslingr's Avatar
Default Steering Link spring loaded ball joint
Doing the font suspension on my 1969 Corvette Convertible 350. After removing the steering linkage arm, I notices a spring loaded ball joint on the driver's side that attaches to the pitman arm. Can someone tell what this is and what this does? Also how to recondition this piece since I am replacing everything else?
Doug
Old 08-04-2013, 10:46 PM
TimAT
TimAT's Avatar
Power steering control valve- IF you have power steering.
Old 08-05-2013, 06:50 AM
Gearslingr
6th Gear
Gearslingr's Avatar
Default Steering Linkage - 69 convert.
TimAT, thank you for the info... now I'm really puzzled. We've got a manual steering gearbox. Humm.. I wonder if any of the other owners before us did some creative parts swaping. So if this is suppose to be a manual steering system that 'spring loaded' ball joint on the linkage arm shouldn't be there?
Doug
Old 08-05-2013, 09:17 AM
TimAT
TimAT's Avatar
The gearbox is still manual. There is the control valve and hoses, attached to a ram that gives the assist. I've not seen a manual system to know for sure if the pitman arm is connected to the other link with the same style spring link.
Ecklers' has listed a replacement end link for the relay rod that appears to have that spring loaded end- for a manual steering system.
Old 08-05-2013, 09:41 AM
Gearslingr
6th Gear
Gearslingr's Avatar
Default Thank you
TimAT, Thank you... I'll check out Eklers listings and see what they've got.
Best Regards,
Doug
Old 08-05-2013, 11:52 AM
0Willcox Corvette
Former Vendor
Willcox Corvette's Avatar
Received 1,813 Likes on 1,458 Posts
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Is this what your looking at? If so, you can purchase a rebuild kit and rebuild it yourself.
http://willcoxcorvette.com/product_i...oducts_id=8754
Old 08-05-2013, 01:16 PM
Gearslingr
6th Gear
Gearslingr's Avatar
Default Thats it
Yes, that's the lil' bugger.
Thank you!
Best Regards,
Cheers..
Doug
Old 08-05-2013, 09:07 PM
TimAT
TimAT's Avatar
I'd go with Willcox-- less $$ and way better service.
To Steering Link spring loaded ball joint
Quick Reply: Steering Link spring loaded ball joint
