Guage lights not working?
Old Jun 29, 2002 | 03:39 AM
Justin79-L-82's Avatar
Justin79-L-82
Default Guage lights not working?
NONE of the guages (speedo, tach, battery, fuel etc) work when i turn on the headlights. It just all of a sudden went out a few nights ago. I checked all the fuses and none of them are burnt. Could a wire have fallen off? How do i fix this nucance?
Old Jun 29, 2002 | 03:55 AM
82dukman's Avatar
82dukman
Default Re: Guage lights not working? (Justin79-L-82)
If it is all of the lights, I suspect a bad headlight switch. Check the instrument cluster ground, it should be right on top of the headlight switch connected to the kick panel vent area.
Old Jun 29, 2002 | 03:59 AM
bluevette's Avatar
bluevette
I've recently had this problem with my 79 also. Turned out to be a bad headlight switch. Pretty easy fix. If you need help with it, just drop another post.
John
Old Jun 29, 2002 | 02:44 PM
Armstrong's Avatar
Armstrong
Check your tail light fuse. I had that problem on mine and found that the tail light fuse being blown will not let power get to the gauge light fuse. Must be a safety thing.
Old Jun 29, 2002 | 03:20 PM
Justin79-L-82
Default Re: Guage lights not working? (Armstrong)
Did you guys with that problem replace the whole headlight switch? The one by the steering wheel?
[Modified by Justin79-L-82, 7:33 PM 6/29/2002]
Old Jun 29, 2002 | 07:56 PM
Metal Wulf's Avatar
Metal Wulf
I had the same problem, replaced the whole switch. pretty easy job just loosen the dash on that side and it'll come right out.
To Guage lights not working?
