Which carburetor?
Old Aug 6, 2013 | 08:51 PM
pontnewynyddboy's Avatar
pontnewynyddboy
Default Which carburetor?
Hi all. Just bought a 77 coupe which has the l48 motor. All stock with 48,000 on it. The car has been sitting for years and the carburetor is in dire need of replacement or a complete rebuild. The carb is a carter q/jet. I was wanting some opinions on which carburetor you would suggest as a replacement or should I go ahead and work with the carter. Any info would be greatly appreciated. Thanks in advance, Bob.T
Old Aug 6, 2013 | 09:06 PM
TimAT's Avatar
TimAT
I'd go with the carb you have. A good rebuild by someone that really knows what's going on in there and can fix the common problems, it'll run better than new.
Old Aug 6, 2013 | 09:58 PM
Shark Racer's Avatar
Shark Racer
What's the part number on the carburetor? I didn't think Carter was casting QuadraJets that late, but I could be wrong. If it's an original late 70's carb it's quite good. You will not get much hp if any by spending hundreds of dollars on another carb.
Old Aug 6, 2013 | 10:14 PM
7T1vette's Avatar
7T1vette
Unless there is some really significant corrosion damage in or on the carb, it should clean up just fine and a rebuild kit and proper set-up and adjustment will yield the right carb for the job.
If you don't want [or feel compentent enough] to do that work yourself and would consider buying an Edelbrock AFB-type carb instead, please don't. Send an e-mail to Lars Grimsrud (V8FastCars@msn.com) asking if he can rebuild your Q-Jet. If he can, he will do a great job....it will be "right" when you get it back. His fees and shipping will likely be around the same or less than what a new Edelbrock with cost--and you don't really want the Edelbrock, IMO.
Old Aug 7, 2013 | 07:32 AM
LudemJo's Avatar
LudemJo
Was the stock Q-Jet a 600 cfm? I have a Edelbrock 1406 on my 74 350/auto, and have been talking with Ryan, one of my forum friends, about replacing it with a Q-Jet 750. I have found rebuilt ones at Jegs for $299.
John
Old Aug 7, 2013 | 08:02 AM
augiedoggy's Avatar
augiedoggy
Carter didn't make the quadrajet? They were made by Rochester ,a division of GM...they may have made some under contract from GM at one point but I never heard of it.
The ones sold by edelbrock are actually Weber carbs made by carter and now edelbrock owns the molds and sent them overseas to china where they now make them.... if you look at the Carb body they still have the Weber logo molded into the side of them... its a true knockoff made from original 50 ? Year old molds.
Old Aug 7, 2013 | 08:30 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by augiedoggy
...Carter didn't make the quadrajet?...
For a while (not sure of specific model years), Carter made Q-Jets under license from Rochester.
Old Aug 7, 2013 | 08:33 AM
7T1vette's Avatar
7T1vette
Carter made lots of Q-Jets. Rochester couldn't make enough of them for GM and others. They are exactly the same except for the cast-in manufacturer name.
Most Q-Jets have 750 cfm capacity; some later versions have 800 cfm.
Old Aug 7, 2013 | 12:01 PM
Shark Racer
And my answer would have mirrored Mike's exactly. I don't know which years that Carter was casting Q-Jets, just that they did. I don't have any in my "collection", but I've seen a few.
Old Aug 7, 2013 | 12:20 PM
augiedoggy's Avatar
augiedoggy
You know I suspected something like thatmay have happened...I might have even read that before , that why I worded my rey as such.
Thanks for the info
Old Aug 7, 2013 | 12:29 PM
qwank's Avatar
qwank
whatever you do, don't put that Edelbrock carb on
Old Aug 7, 2013 | 05:39 PM
pontnewynyddboy
Thanks for all the help guys. Definatly a carter. The casting says quadrajet mfg by carter for gm. Thanks 7t1 for the email info. I will be contacting him very soon for the rebuild.
Old Aug 7, 2013 | 06:54 PM
gcusmano74's Avatar
gcusmano74
Yes. Keep the Qjet. Talk to Lars, and let him rebuild your carb.
Old Aug 7, 2013 | 09:49 PM
scottyp99's Avatar
scottyp99
I've never had occasion to have Lars do any work for me, so I can't speak from experience, but I will say this: I have never heard anybody complain about his work. Ever. And that's saying something.
Scott
Old Aug 7, 2013 | 09:51 PM
Flyinace3's Avatar
Flyinace3
I would talk to Lars. I was in a time crunch wanting to go to the saint Ignace car show and cruise and installing my headers/ sidepipes and found out it was running lean afterwards. I ordered a q jet from kegs. So far it's worked out really good out of the box. This winter I am going to install a 383 and I am going to talk with Lars to get the right carb.
Old Aug 7, 2013 | 10:50 PM
Shark Racer
What's the P/N on the carburetor? Should be on the driver's side of the carb, facing forward. Will be a 7 digit number starting with 70 or an 8 digit number starting with 170.
If you can get pics of the carb all the better.
Old Aug 8, 2013 | 09:19 AM
7t9l82's Avatar
7t9l82
send your carb and distributor to Lars.
or may i recommend 6 stromberg 97's
To Which carburetor?
Old Aug 8, 2013 | 11:35 AM
commander_47's Avatar
commander_47
The q jet is junk. I would immediately throw it away and get a Holley.
Carter made Q junk licensed from GM. Rochester isn't a company, its the town the GM carb plant is in. Somehow they started calling them Rochesters.
A lot of folks live in a CFM fantasy world. Just because the the Q junk is allegedly capable of 750 CFM, it NEVER gets there.
Your motor will only draw as much air and fuel as it needs. That is why the Q junk has the two small main bores. 90% of the time you are driving on those two small ones sucking in 500 cfm.
If you happen to stomp on the gas, and if the rest of the system (intake manifold, valves, etc) can handle it, you may, but probably not, draw 650 tops for a brief second on a bone stock 350.
You can waste your money and time rebuilding an old Q junk or get a 650 Holley that is bolt on and will improve performance.
Fact of the matter is, on a bone stock car you can run a nice 600 and never ever have any issues. I ran one of these for years:
http://www.holley.com/0-80457S.asp
I only traded up to a Street Avenger 650 because of some performance upgrades.
Old Aug 8, 2013 | 01:09 PM
7T1vette's Avatar
7T1vette
Obviously a personal bias [vendetta] from the prior post. Ignore it, instead.
Old Aug 8, 2013 | 02:44 PM
BlackC3vette's Avatar
BlackC3vette
pontnewynyddboy,
Do not throw your existing Q-Jet away. A good rebuild-able core can run $100, so if you don't get it rebuilt, stick it up on the shelf in a plastic bag.
I have used Holley carbs on my projects in the past and I probably will again. But, if your motor is stock right now and you are keeping it that way, I would have Lars rebuild your Q-Jet. If you are looking at rebuilding your engine and staying under 400hp, I would have Lars rebuild the Q-Jet for now, at least. You just need to let him know what all the engine/tranny/gear details are and he will set the carb up for you. His prices are very reasonable.
